Normal Topic 'MindFusion' is undefined - getting my feet wet with Canvas mode (Read 7391 times)
jlj30
Feb 17th, 2014 at 7:11pm
I have taken a copy of the FlowCharter demo page, modified it slightly and included it in my current asp.net application.
When I try and access this page I get the following error:
0x800a1391 - JavaScript runtime error: 'MindFusion' is undefined
Here's my aspx page. The failing line is highlighted:
Code (HTML)
<%@ Page Title="" Language="C#" MasterPageFile="~/ITO.master" AutoEventWireup="true" CodeFile="P_CFFD_DD_POC.aspx.cs" Inherits="P_CFFD_DD_POC" %>
<%@ Register Assembly="MindFusion.Diagramming.WebForms" Namespace="MindFusion.Diagramming.WebForms" TagPrefix="ndiag" %>
<asp:Content ID="Content1" ContentPlaceHolderID="head" runat="Server">
</asp:Content>
<asp:Content id="Content2" contentplaceholderid="ContentPlaceHolder" runat="Server">
    <div style="float: left;">
        <ndiag:ShapeListBox ID="shapeList" runat="server" ClientSideMode="Canvas" DefaultShapeSize="20,20" JsLibraryLocation="~/Js/MindFusion.Diagramming.js"
            Style="width: 140px; height: 400px; background-color: white" ShapeFillColor="WhiteSmoke" BorderColor="Black" IconSize="20,20" />
    </div>
    <div>
        <ndiag:DiagramView runat="server"
            ID="diagramView"
            Style="height: 400px; width: 650px;"
            NodeCreatedScript="onNodeCreated"
            AllowInplaceEdit="true"
            Diagram-RouteLinks="true" />
    </div>
    <div style="clear:both;">
        <br />
        <asp:Button ID="btnSave" runat="server" OnClick="btnSave_Click"
            Text="Save" Width="111px" />
        <asp:Button ID="btnLoad" runat="server" Style=""
            Text="Load" Width="111px" OnClick="btnLoad_Click" />
        &nbsp;
        <asp:TextBox ID="tbFileName" runat="server">untitled.fc</asp:TextBox>
        <asp:DropDownList ID="listFileNames" runat="server">
        </asp:DropDownList>
    </div>
    <script type="text/javascript">
        var AnchorPattern = MindFusion.Diagramming.AnchorPattern;
        function onNodeCreated(sender, args) {
            var node = args.getNode();
            node.setAnchorPattern(AnchorPattern.decision1In3Out);
            node.setBrush({ type: 'SolidBrush', color: '#B0C4DE' });
    </script>
</asp:Content>
Since I'm new to canvas mode, I'm sure I've missed something.
Thanks in advance for helping me get past this Smiley
Jim
Re: 'MindFusion' is undefined - getting my feet wet with Canvas mode
Reply #1 - Feb 18th, 2014 at 7:47am
Check the generated HTML to see if the resolved diagramming.js URL is in the expected folder. Also try to download it by copying the URL to browser address bar to verify IIS has permissions to the folder.
Note that you must load Microsoft Ajax before diagramming.js; in the samples that's done implicitly by the asp:ScriptManager tag, but you could also load it using a <script src=Microsoft.Ajax.js> tag.
jlj30
Reply #2 - Feb 18th, 2014 at 3:20pm
I have added the following to the head of my page:
Code (HTML)
     <script src="MicrosoftAjax.js" type="text/javascript"></script>
     <script src="MindFusion.Diagramming.js" type="text/javascript"></script>
</asp:Content>
Remember, I'm using a master page.
The result is that I can now run in FireFox and Chrome (I actually placed alerts in the onNodeCreated function and they fire). Plus I now see the anchor handles on the shapes when I hover them.
However, IE is a problem; at least when I emulate IE7 and IE8 from the Developers Tools page. Selecting IE9, 10 or Edge for Document mode works fine.
Here are the error messages for IE7 and IE8:
IE7:
Unhandled exception at line 1, column 1 in http://vs2013-jim/NavviaNewDev/MindFusion.Diagramming.js
0x800a0404 - JavaScript runtime error: Expected identifier, string or number
IE8:
Unhandled exception at line 1, column 243342 in eval code
0x800a01b6 - JavaScript runtime error: Object doesn't support property or method 'addEventListener'
Many of our clients are still running IE8, so hopefully you can shed some light on what might be happening.
Jim
Reply #3 - Feb 18th, 2014 at 4:12pm
Unfortunately earlier IE versions do not support the HTML5 Canvas element; it was first implemented in IE9.
jlj30
Reply #4 - Feb 18th, 2014 at 4:18pm
Ah yes.
Thanks for the prompt reply.
Time for us to get our clients to get current Smiley
Jim
