Normal Topic Movement of an DiagramNode within ContainerNode (Read 1756 times)
Kuzya
Mar 21st, 2014 at 9:16am
Hello together,
If I shift a DiagramNode within ContainerNode, I would like to check the direction of movement.
How can I make this?
Many thanks in advance
Kyzya
Re: Movement of an DiagramNode within ContainerNode
Reply #1 - Mar 21st, 2014 at 11:05am
Try this if you need to detect the direction in which the user moves a node interactively:
PointF startPoint = new PointF();
private void diagram_NodeStartModifying(object sender, NodeValidationEventArgs e)
	startPoint = e.Node.GetCenter();
private void diagram_NodeModified(object sender, NodeEventArgs e)
	var currentPoint = e.Node.GetCenter();
	bool left = currentPoint.X < startPoint.X;
	bool right = currentPoint.X > startPoint.X;
	bool up = currentPoint.Y < startPoint.Y;
	bool down = currentPoint.Y > startPoint.Y;
Kuzya
Reply #2 - Mar 21st, 2014 at 12:29pm
Thank you very much! The solution is perfect!
