Normal Topic Disable Default Rendering (Read 3361 times)
Achim
MindFusion rocks!
Apr 4th, 2014 at 7:25am
Hi there,
I know we had a discussion about this topic over a year ago. When I want to custom draw Items in the resource view I can make use of the ItemDrawing event. A handler of this event can set args.Handled = true to disable the default rendering logic.
Now I want to be able to skip the default rendering for other parts (like ResourceRowHeaders) too. Is there already a way to skip certain elements?
Best regards
Achim
Re: Disable Default Rendering
Reply #1 - Apr 4th, 2014 at 8:20am
I don't believe there is currently a way to skip the rendering of elements other than items. Do you need this in order to improve performance? If this is the case, I doubt there will be a noticeable difference with and without the default rendering. In any case we will see if we can extend the control to support this.
Achim
MindFusion rocks!
Reply #2 - Apr 4th, 2014 at 9:07am
Hi Meppy,
I agree with you regarding performance. This is more a suggestion to make the API and the behavior a bit cleaner for developers who intensively use custom drawing.
Achim
