Normal Topic SetViewPort() in ResourceView (Read 12095 times)
Achim
MindFusion rocks!
Apr 4th, 2014 at 12:53pm
Hi there,
I just wanted to implement some "fit to content" functionality and stumbled upon SetViewPort() which looks it should do the job for me Smiley Luckily it works as espected but only one time. When I call the function a second time the result gets weird: the timeline gets very long and no items are visible on the chart. When I scroll up and down a bit and then call SetViewPort() again, sometimes it works correctly again. I'm sure I pass always the same arguments to the function (StartTime, EndTime and the scale flag).
Any help on this?
Best regards
Achim
Re: SetViewPort() in ResourceView
Reply #1 - Apr 7th, 2014 at 5:53am
This appears to be a bug. Please, check if the trial version below addresses the issue. A release with the fix will be available later.
https://mindfusion.eu/_temp/MindFusion.Scheduling.5.5.1.trial.zip
Achim
MindFusion rocks!
Reply #2 - Apr 7th, 2014 at 7:42am
Hi Meppy,
thank you, seems to work as expected Smiley Please let me know when the release is available.
Regards
Achim
Reply #3 - Apr 7th, 2014 at 10:38am
We do not have a set date for the next official release. I have sent you private message with a temporary link to the most recent licensed assemblies of MindFusion.Scheduling. These assemblies also include the Drawing event we discussed earlier.
Achim
MindFusion rocks!
Reply #4 - Apr 7th, 2014 at 11:31am
Hi Meppy,
thanks a lot four your fast response.
I've double checked the functionality of SetViewPort() in the meantime and found two little issues:
1. sometimes I have to call the method twice in order to get the expected result (after the first call I can see about 90% of the content, after the second I see the exact range)
2. When I  call SetViewPort() call a horizontal scroll bar remains which scrolls a little bit more than the given range. This is also the case when I set a wider range than defined by calendar.Date and calendar.EndDate.
Thanks for your support
Achim
Reply #5 - Apr 7th, 2014 at 2:19pm
Are you able to provide me with your settings at the time these problems happen? More specifically, the timeline settings of the view.
SGS Software
Reply #6 - Sep 30th, 2014 at 1:21pm
Hi, I pick this topic up instead of opening a new one.
My scenario is ResourceView, VB.NET
Can I set again my own format of each date/time row
after I set the parameter "adjustResolution" True?
There is a method to handle the format to make it custom?
For example, I want to make day week name one char only (M,T,W,T,F,S,S)
or make the month name uppercase...is it possible?
Thank you.
Reply #7 - Sep 30th, 2014 at 2:42pm
You can customize the texts displayed in the timelines of the Resource view through the Format property of the respective TimelineSettings object, that is, ResourceViewSettings.TopTimelineSettings, ResourceViewSettings.MiddleTimelineSettings, and ResourceViewSettings.BottomTimelineSettings for the top, middle, and bottom timelines respectively. The accepted values for the Format property are the standard date and time formatting specifiers, as outlined in the Custom Date and Time Format Strings topic of the MSDN documentation. However, I don't think there is a specifier for just the first letter of the day of the week.
You have the following two options:
You can set the format to "ddd" (The abbreviated name of the day of the week.) and replace the abbreviated day names globally, by setting the Calendar.DateTimeFormat.AbbreviatedDayNames:
calendar.DateTimeFormat.AbbreviatedDayNames = New String() {"S", "M", "T", "W", "T", "F", "S"}
Specifying uppercase month names can be done in a similar fashion by setting the Calendar.DateTimeFormat.MonthNames property. Keep in mind that this will affect the display of the abbreviated day names and months throughout the entire control.
Alternatively, you can handle the Calendar.CustomizeText event and provide the texts yourself. To provide texts for the resource view timelines, you need to check if the value of the Element property of the event argument equals CalendarTextElements.ResourceViewTimeline. You need to analyze the date of the cell being processed and return a corresponding text value. The following event handler returns uppercase month names for the cells in the middle timeline and a single-letter day names for the cells in the bottom timeline:
If e.Element = CalendarTextElements.ResourceViewTimeline Then
	If e.Index = 1 Then
		' Middle timeline
		e.Text = calendar.DateTimeFormat.MonthNames(e.[Date].Month - 1).ToUpper()
	ElseIf e.Index = 2 Then
		' Bottom timeline
		e.Text = calendar.DateTimeFormat.AbbreviatedDayNames(CInt(e.[Date].DayOfWeek))(0).ToString()
	End If
End If
Let me know if this helps.
SGS Software
Reply #8 - Sep 30th, 2014 at 3:05pm
The "AbbreviatedDayNames" is the best and quick solution for me, now!
Before, I was thinking about a CustomDraw event, but "e.Text" was ReadOnly, didn't know about CustomizeText event, so I ended up with draw a rectangle cointaining a string...same result (maybe) but more elaborate!
Thank you!
What about the other question about set again the format after
SetViewPort with "adjustResolution" = True?
Reply #9 - Oct 1st, 2014 at 6:15am
You can set the format of the dates in the timelines through the Format property of the respective TimelineSettings object. For example, to set the format of the bottommost timeline, you could use the following code:
calendar.ResourceViewSettings.BottomTimelineSettings.Format = "ddd"
I hope this helps.
