Normal Topic How to Get the diagram item's text ? (Read 5383 times)
BabyTL
Apr 11th, 2014 at 6:51am
All i know is that the diagram consisting of the "diagramNode"(Shape) ,and i want to get zhe shape text from the diagram.But How? :-[
eg:
     [color=#00ff00][b]ShapeNode diagramNode = diagram.Factory.CreateShapeNode(bounds, shape);
     diagramNode.Text = "abc";[/b][/color]
and [color=#ff00ff][b]how to get the text:"abc" from the diagram[/b][/color] using code?
BabyTL
Re: How to Get the diagram item's text ?
Reply #1 - Apr 11th, 2014 at 6:51am
[quote author=30302A2B263E520 link=1397199072/0#0 date=1397199072]All i know is that the diagram consisting of the "diagramNode"(Shape) ,and i want to get zhe shape text from the diagram.But How? :-[
eg:
and how to get the text:"abc" from the diagram using code?[/quote]
Reply #2 - Apr 11th, 2014 at 7:01am
There are different properties for text such as ShapeNode.Text and TableNode.Caption. You could either use type-casting, or access text values via the InplaceEditable interface:
foreach (var item in diagram.Items)
	var textItem = (InplaceEditable)item;
	Debug.WriteLine(textItem.GetTextToEdit());
	var shapeNode = item as ShapeNode;
	if (shapeNode != null)
		Debug.WriteLine(shapeNode.Text);
BabyTL
Reply #3 - Apr 11th, 2014 at 7:26am
[quote author=092E3523355A0 link=1397199072/2#2 date=1397199717]There are different properties for text such as ShapeNode.Text and TableNode.Caption. You could either use type-casting, or access text values via the InplaceEditable interface:
[code]
}[/code]
Stoyan[/quote]
TY ! I got some diagramNode eg-nodemap:x,y,z.. and i use the diagramlink to link them. I want to kown the every link's start node(eg:x) and the end node(eg:y).What way? Also how ~ let those links don't cross the nodes ?eg the file"2014.png" :)
Reply #4 - Apr 11th, 2014 at 7:37am
You can find which nodes are connected by a link via the link's Origin and Destination properties. Try calling the RouteAllLinks method to re-route links away from nodes.
BabyTL
Reply #5 - Apr 11th, 2014 at 8:00am
TY Stoyan ! I Get It !  But the RouteAllLinks method is not useful ~~ Sad
Even so, I sincerely thank you for your help!
Reply #6 - Apr 11th, 2014 at 8:27am
RouteAllLinks should work as long as you don't have some large background node in the diagram. If there is one, set its Obstacle property to false.
Also make sure you call the method after applying any layout algorithm or placing the nodes yourself from code. E.g. you might get links passing over nodes if you call TreeLayout.Arrange on a diagram that's not strictly a tree (it ignores links that are not part of the diagram's spanning tree):
treeLayout.Arrange(diag);
diag.RouteAllLinks();
BabyTL
Reply #7 - Apr 12th, 2014 at 4:55am
TY Stoyan ! Smiley
