Normal Topic HitTestOffset for tool tips (Read 4533 times)
znavot
Apr 24th, 2014 at 8:15am
I'm looking for a way to control the tolerance of a tooltip.
In a previous thread, the use of HitTestOffset property was suggested. However, it seems this property is relevant only to a click event, while tooltips are initiated by hovering.
So even when setting a HitTestOffset to a very small value,
it does not affect the tooltip (see attached picture in which I hover next to point 4, but still get the tooltip related to point 3).
To reproduce this behavior, I used the next code in MindFusion Demo application in ProfitForm.cs:
this.lineChart1.ShowToolTips = true;
this.lineChart1.ToolTipText = new MindFusion.Charting.LabelsCollection("1,2,3,4,5,6,7,8");
this.lineChart1.HitTestOffset = 1;
I would appreciate your help.
Nir
Re: HitTestOffset for tool tips
Reply #1 - Apr 28th, 2014 at 12:16pm
You can find updated assemblies that should fix that on the PM page.
znavot
Reply #2 - Apr 28th, 2014 at 12:56pm
Hi Stoyan,
It works much better now.
Nir
