Normal Topic link issues (Read 5171 times)
Pratik
link issues
May 15th, 2014 at 11:48am
See the below image when i draw two links between two node i got link drawn on each other but i want both link sepratly
Re: link issues
Reply #1 - May 15th, 2014 at 12:55pm
Try handling the LinkCreated event as in http://mindfusion.eu/Forum/YaBB.pl?num=1266388133/8#8
Pratik
Re: link issues
Reply #2 - May 16th, 2014 at 5:09am
It will not work for me.
see my problem is shown in first image
and i want solution shown in second image when i draw link
Re: link issues
Reply #3 - May 16th, 2014 at 7:48am
That's exactly what that code does:
Have you set the first method as handler for DiagramView.LinkCreated? Or if you need to apply it for links that you create from code, refactor the LinkCreated handler to take a single link argument and call it after CreateDiagramLink.
Pratik
Re: link issues
Reply #4 - May 20th, 2014 at 9:27am
I want allow user to draw only two link between node not more then two link .. Smiley
Pratik
Re: link issues
Reply #5 - May 20th, 2014 at 10:28am
As shown in below image i want to allowed user to draw only two link between node and not allowed to draw 3rd link between this two node. Roll Eyes
Re: link issues
Reply #6 - May 20th, 2014 at 10:39am
In Canvas mode you could disable additional links from LinkCreatingScript. This is not supported in ImageMap mode, so you might have to delete extra links after the fact, from LinkCreated handler on server side.
Pratik
Re: link issues
Reply #7 - May 20th, 2014 at 11:40am
Thank for  reply
so in image map i have to delete extra link there is no way to handle it..
