Normal Topic Removing commands from the undo stack (Read 1736 times)
j poz
May 15th, 2014 at 3:40pm
Is it possible to remove commands from the undo stack without executing them?
j poz
Re: Removing commands from the undo stack
Reply #1 - May 15th, 2014 at 3:42pm
(Not all of the commands, via Clear(), just some of them..)
Reply #2 - May 16th, 2014 at 6:39am
You could filter them out from the ActionRecording event handler by setting args.Cancel = true.
