Page Index Toggle Pages: 1 ... 19 20 [21]  Send TopicPrint
Locked Topic Link between two nodes (Read 129234 times)
shrinivas
Re: Link between two nodes
Reply #300 - Sep 18th, 2014 at 6:47am
Stoyo wrote on Sep 12th, 2014 at 2:20pm:
Try this version, it should export individual diagrams faster:
https://mindfusion.eu/_beta/netdiag531.zip
The 300 nodes + 1200 links one takes about 30 seconds now, so if you export all diagrams as individual files the 104 files should finish in less than an hour (excluding load and layout times). We can't see any way to reduce the memory footprint, so it will still slow down if you try to export a 100-page DiagramDocument once the in-memory XML document gets very large and the system starts paging.
I am using this version but still issue is not solved Its taking 18 hours and after that throws exception :
Function evaluation disabled because a previous function evaluation timed out. You must continue execution to reenable function evaluation.
Reply #301 - Sep 19th, 2014 at 9:33am
It took about 50 minutes in our test to export separate files per each diagram. If the same takes 18 hours for you, probably you have CPU throttling enabled in IIS:
http://www.iis.net/learn/get-started/whats-new-in-iis-8/iis-80-cpu-throttling-sa...
http://blogs.iis.net/shauneagan/archive/2012/03/15/cpu-throttling-iis-7-vs-iis-8...
We've also tried exporting a DiagramDocument with all pages to the same VDX, which keeps all diagrams and XML in RAM, and at the 20th page the process took 1GB of RAM, so you will probably reach the max Windows address space of 2 GB at about the 40th page and won't be able to export all files to same VDX anyway.
Reply #302 - Sep 24th, 2014 at 1:59pm
This new build now takes about 5 seconds to export a 1500-items diagram to VDX:
On our test system it takes less than 8 minutes to export the 104 pages separately:
// load time: 00:02:08.9703767
// layout time: 00:08:15.4793398
// export time: 00:07:22.7483237
var document = new DiagramDocument();
var startTime = DateTime.Now;
var dirInfo = new DirectoryInfo(@"C:\temp\XML");
foreach (var fileInfo in dirInfo.GetFiles("*.xml"))
	var page = new DiagramPage();
	page.LoadFromXml(fileInfo.FullName);
	document.Pages.Add(page);
	page.Title = fileInfo.Name;
Debug.WriteLine("load time: " + (DateTime.Now - startTime));
foreach (var page in document.Pages)
	var dl = new DecisionLayout();
	dl.Orientation = MindFusion.Diagramming.Layout.Orientation.Vertical;
	dl.HorizontalPadding = 10;
	dl.VerticalPadding = 10;
	dl.Arrange(page);
Debug.WriteLine("layout time: " + (DateTime.Now - startTime));
	new VisioExporter().Export(page, @"C:\test.vdx");
Debug.WriteLine("export time: " + (DateTime.Now - startTime));
You still won't be able to fit all 104 diagrams and Visio XML in the process memory, so if you need them merged in the same VDX, try using the .NET XML API to create it. E.g. you could export the pages separately, unload all diagrams to free memory, then copy individual Page element from each exported file to a merged file under the parent <Pages> element.
shrinivas
Reply #303 - Oct 20th, 2014 at 5:56am
Have you added support for hyperlink in VISIO ?
Stoyo wrote on Aug 14th, 2014 at 11:27am:
No, here's what I said previously:
http://mindfusion.eu/Forum/YaBB.pl?num=1400652920/261#261
Until we add support for hyperlinks to VisioExporter you won't be able to implement them via diagram properties, you'll have to add respective Visio XML elements to the VDX file instead.
Reply #304 - Oct 21st, 2014 at 8:31am
The latest build here supports hyperlinks:
https://mindfusion.eu/_beta/netdiag.5.4.zip
Set node.HyperLink to either a page name or a web address and VisioExporter will generate appropriate XML markup.
