Normal Topic Problem with layouts (Read 6263 times)
Dunedan
Jun 10th, 2014 at 4:07pm
I have 3 questions:
- Is it possible to reduce the time of the AnnealLayout and TriangleLayout ? It takes a long time and I don't have seen any iteration parameter ?
- I have a bug with the GridLayout (with 500 nodes and 4500 links):
java.lang.IllegalArgumentException: Comparison method violates its general contract!
     at java.util.TimSort.mergeHi(Unknown Source)
     at java.util.TimSort.mergeAt(Unknown Source)
     at java.util.TimSort.mergeForceCollapse(Unknown Source)
     at java.util.TimSort.sort(Unknown Source)
     at java.util.Arrays.sort(Unknown Source)
     at java.util.Collections.sort(Unknown Source)
     at com.mindfusion.common.ExtendedArrayList.sort(Unknown Source)
     at com.mindfusion.diagramming.QuickRouter.a(Unknown Source)
     at com.mindfusion.diagramming.QuickRouter.RouteLinks(Unknown Source)
     at com.mindfusion.diagramming.Diagram.routeAllLinks(Unknown Source)
     at com.mindfusion.diagramming.GridLayout.arrange(Unknown Source)
Code (Java)
    	com.mindfusion.diagramming.GridLayout gridLayout = new com.mindfusion.diagramming.GridLayout();
	    	gridLayout.setGridSize(100);
	    	gridLayout.setIterations(19);
	    	gridLayout.setKeepGroupLayout(true);
	    	gridLayout.setRandomSeed(0);
	    	gridLayout.setXGap(12.5f);
	    	gridLayout.setYGap(12.5f);
	    	gridLayout.arrange(diagram);
One remark: I can have 2 links between 2 nodes.
- And one last question (not related to layouts): is it possible to have the nodes always displayed above the links ?
Re: Problem with layouts
Reply #1 - Jun 10th, 2014 at 7:54pm
You can set AnnealLayout's Stages and IterationsPerStage properties.
TriangularLayout is designed for planar and close to planar graphs, and will waste a lot of time on a planarization step done for each non-planar link. A graph is planar only if num_links ≤ 3*num_nodes − 6, so you have at least 3000 non-planar links to process for the 500 nodes and 4500 links example. You might try setting IgnoreLayout = true for all links above the 3*nodes index in diagram.Links collection to make the processed graph sparser and closer to planar, and just reset them to straight lines after layout completes.
Could you attach the diagram that reproduces that saved as XML file?
Set higher ZIndex value for nodes.
Dunedan
Reply #2 - Jun 11th, 2014 at 8:13am
Hi, I can't post the diagram (too large). I will send an email.
Thanks.
Reply #3 - Jun 11th, 2014 at 8:34am
This worked in our test project with the GridLayout code from your post. Are you using latest version of the control, and what JRE version do you have installed?
Dunedan
Reply #4 - Jun 11th, 2014 at 3:01pm
I am using official JDiagram 4.0.5.
I have tested with JRE 1.7 and 1.8. And I have the error with both.
I have:
diagram = new Diagram();
Rectangle2D bounds = new Rectangle(0,0,800,600);
diagram.setBounds(bounds);
diagram.setLinkShape(com.mindfusion.diagramming.LinkShape.Bezier);
diagram.setLinksRetainForm(true);
diagram.setShapeHandlesStyle(HandlesStyle.Custom);
diagram.setDefaultShape(Shape.fromId("Rectangle"));
diagram.setAlignToGrid(false);
diagram.setAllowLinksRepeat(true);
diagram.setAllowSplitLinks(true);
     diagram.setAutoResize(AutoResize.AllDirections);
diagram.setRestrictItemsToBounds(RestrictToBounds.Intersection);
diagram.setDynamicLinks(true);
diagram.setBackBrush(new SolidBrush(Color.white));
diagram.setShadowsStyle(ShadowsStyle.None);
Reply #5 - Jun 11th, 2014 at 3:35pm
Ok, we were running it on Java 6 and reproduced the exception on Java 7. Our developer will investigate.
Reply #6 - Jun 12th, 2014 at 6:18am
Please try the version from PM page, linked from top of the forum.
Dunedan
Reply #7 - Jun 12th, 2014 at 10:14am
Yes, it is working now (java 7 and java 8).
Thanks !
