Normal Topic Bugs in showing container in the ASP.NET MVC version (Read 3643 times)
Homam
Jul 7th, 2014 at 1:08pm
I managed to render a saved diagram via a windows application. There are so far two obvious bugs.
First, The container is rotated 90" in the original diagram but it is not showing correctly in the MVC version.
Second, the title of the container is centered in the original one. And it is aligned left in the MVC one.
Re: Bugs in showing container in the ASP.NET MVC version
Reply #1 - Jul 7th, 2014 at 1:38pm
The JavaScript library can rotate only ShapeNodes at this time. We'll try to add support for rotated containers for next release.
Homam
Reply #2 - Jul 20th, 2014 at 10:07am
Is there any workaround for now?
It is very critical  for us.
Reply #3 - Jul 21st, 2014 at 6:12am
You can find pre-release build with some rotation support on PM page. It should show rotated containers correctly if you load from WinForms, but we haven't ported all interaction code yet and some things like resizing rotated containers on client side will not work as expected.
