Normal Topic Nodes occasionally jump around weirdly if calling layout.Arrange(diagram) periodically (Read 5239 times)
dossantos
Jul 10th, 2014 at 1:24pm
Hi all,
I call layout.Arrange(diagram) on a SpringLayout periodically from a worker thread (using diagramView.Invoke for safety), and this works really well! It's even possible to modify the diagram during this (setting LayoutTraits.Freeze on the modified node during its modification). This is so cool! Smiley
I noticed a strange behaviour, though. Here's a screencast showing the issue:  http://youtu.be/fkux7L_Kn1Q
Sometimes (not always), single nodes suddenly "jump" to a completely different location (see the linked screencast). I didn't interfer with the diagram in any way during the "jumps".
This looks like some computation error inside the layout algorithm or something...
Can you explain this behaviour?
  Tim
Re: Nodes occasionally jump around weirdly if calling layout.Arrange(diagram) periodically
Reply #1 - Jul 10th, 2014 at 1:47pm
This might be a result of the MinimizeCrossings property, which kind-of shakes the graph at each 10th step to try if a different local configuration will decrease crossings. It is enabled by default, so try setting it to false.
Reply #2 - Jul 10th, 2014 at 1:53pm
We have a similar AnimatedLayout example coming with WPF version of the control, and now I see that it explicitly sets layout.MinimizeCrossings = false; so that's it I suppose.
dossantos
Reply #3 - Jul 10th, 2014 at 2:04pm
No, MinimizeCrossings doesn't seem to make a difference.
But, I noticed I still had EnableParallelism = true, so I deactivated that one and it seems to have solved the issue!
I'll let you know if it occurs again, but since I disabled parallelism, I didn't see jumpy nodes again.
  Tim
dossantos
Reply #4 - Jul 10th, 2014 at 2:11pm
Well, it seems to still occur, even with no parallelism. sigh.
I'll investigate further.
I noticed, though, that it seems to happen only with the rightmost nodes - could it be some issue with the diagram's bounds?
Reply #5 - Jul 10th, 2014 at 3:19pm
Try running with the code below copied from the sample project, or post your code with attached diagram file and our developer will check it.
private void InitSpringLayout()
	layout = new SpringLayout();
	layout.NodeDistance *= 2.0 / 3;
	layout.IterationCount = 1200;
	layout.SplitGraph = false;
	layout.LayoutMethod = SpringLayoutMethod.Classic;
	layout.BeginArrange(diagram, null);
	iteration = 0;
dossantos
Reply #6 - Jul 15th, 2014 at 7:06am
I'll try to prepare an isolated testcase and will send it to you. Until then, thanks so far Smiley
dossantos
Reply #7 - Jul 15th, 2014 at 9:08am
I isolated the behaviour in a small test application. Please refer to the attached solution; I can reproduce the behaviour every time by running the program and checking the "animate" checkbox.
Please tell me if this is appropriate for debugging!
Tim
MindFusionTest.zip (Attachment deleted)
Reply #8 - Jul 15th, 2014 at 11:05am
That happens because when you call Arrange, SpringLayout calculates initial layout area based on number and size of nodes, and pulls all nodes inside it. After a few hundred Arrange calls the rightmost node gets outside the calculated area and you see it pulled back in.
You could use the built-in animation methods of SpringLayout (BeginArrange, Iterate, EndArrange), and the layout area check will be done only in the beginning:
this.diagram1.LoadFromFile("test.diag");
var sl = new SpringLayout
	Anchoring = Anchoring.Ignore,
	IterationCount = 5,
	NodeDistance = 50,
	MinimizeCrossings = false,
	GrowToFit = false,
	EnableClusters = false,
	LinkType = SpringLayoutLinkType.Straight,
	//EnableParallelism = false,
	Randomize = false // nicht random, sondern die initiale Partitionierung (s.o.) beachten!
sl.BeginArrange(diagram1, null);
this.layout = sl;
private void HandlesAnimTimerTick(object sender, EventArgs args)
	var sl = this.layout as SpringLayout;
	if (sl != null)
		sl.Iterate(0, 5);  // this won't pull back nodes anymore
Alternatively keep using Arrange, but set SpringLayout.LayoutArea to the GetContentBounds() rectangle inflated by some margin area before each Arrange call.
