Normal Topic take a div containing the Canvas and make it Fullscreen (Read 2067 times)
agelospanagiotakis
Jul 13th, 2014 at 9:16am
Is there any way to take a div containing the mindfusion canvas and make it Fullscreen so that the user can only work on the diagram for a while and then return to the attach it back to a div when done ?
Re: take a div containing the Canvas and make it Fullscreen
Reply #1 - Jul 14th, 2014 at 8:03am
Try the following
function fullScreen()
	var parentDiv = document.getElementById("view");
	var diagram = MindFusion.Diagramming.Diagram.find("diagram");
	if (enterFullScreen(parentDiv))
		var docWidth = diagram.clientToDocLength(screen.width);
		var docHeight = diagram.clientToDocLength(screen.height);
		var bounds = diagram.getBounds().clone();
		if (bounds.width < docWidth || bounds.height < docHeight)
			bounds.width = docWidth;
			bounds.height = docHeight;
			diagram.setBounds(bounds);
function enterFullScreen(element)
	if (element.requestFullscreen)
		element.requestFullscreen();
		return true;
	if (element.msRequestFullscreen)
		element.msRequestFullscreen();
		return true;
	if (element.mozRequestFullScreen)
		element.mozRequestFullScreen();
		return true;
	if (element.webkitRequestFullscreen)
		element.webkitRequestFullscreen(Element.ALLOW_KEYBOARD_INPUT);
		return true;
	return false;
Check this MDN topic for a list of supported browsers:
https://developer.mozilla.org/en-US/docs/Web/Guide/API/DOM/Using_full_screen_mod...
