Normal Topic AllowDrag ineffective (Read 3773 times)
DoctorsDad
Jul 23rd, 2014 at 9:04am
In the Calendar control (Winforms 5.2.0.15247) I have AllowDrop = true and AllowDrag = false.
I can drop items on to the form and that works fine but the control still allows me to drag items around without firing any events.
As I read the docs, setting AllowDrag = false should prevent dragging.
If I can't prevent it, how do I trap it?
Re: AllowDrag ineffective
Reply #1 - Jul 23rd, 2014 at 9:42am
The AllowDrag property only concerns the OLE Drag & Drop. If you want to prevent the user from modifying items interactively inside the control, you can either lock the items (by setting their Locked property to true) or handle the ItemModifying event of the Calendar class and set the Confirm property of the event argument to false.
