Normal Topic Strange isue with container (Read 2172 times)
PDM.
Senior Member
Jul 23rd, 2014 at 1:15pm
foreach (var node in form.Nodes)
var adapter = node as DiagramNodeAdapter;
if (adapter != null && adapter.Control is ContainerNode)
if (adapter.Selected == true)
ContainerNode c = (ContainerNode)adapter.Control;
c.Stroke = mycolor;
c.CaptionBackBrush = mycolor;
This code work correclty for all my nodes, but not for containers.
Stoyo, you see sometghing wrong in the code?
Re: Strange isue with container
Reply #1 - Jul 23rd, 2014 at 1:31pm
Are you sure your containers are inside adapters? Try this instead:
    var container = node as ContainerNode;
    if (container != null && container.Selected)
        container.Stroke = mycolor;
        container.CaptionBackBrush = mycolor;
    // ... handle adapters next
PDM.
Senior Member
Reply #2 - Jul 23rd, 2014 at 2:05pm
Ok, this way solve the isue. THK!
Why containers nor are inside DiagramNodeAdapter?
Reply #3 - Jul 23rd, 2014 at 2:08pm
DiagramNodeAdapter is used to host custom controls that do not derive from DiagramNode. You could probably host a container inside DiagramNodeAdapter too, but then some features might not work, such as adding children to the container interactively or folding it.
PDM.
Senior Member
Reply #4 - Jul 23rd, 2014 at 2:09pm
Thankyou!
Very usefull info!
