Normal Topic Adjustment handles draw order (Read 3414 times)
j poz
Jul 29th, 2014 at 5:01pm
Is there a way I can draw the adjustment handles before the Draw() method gets called on a ShapeNode?
Re: Adjustment handles draw order
Reply #1 - Jul 29th, 2014 at 6:13pm
If using a derived node type, you could implement that by overriding Draw and DrawHandles:
public override void Draw(IGraphics graphics, RenderOptions options)
	if (this == Parent.ActiveItem)
		base.DrawHandles(graphics, Parent.ActiveItemHandlesStyle, options);
	else if (Selected)
		base.DrawHandles(graphics, Parent.SelectedItemHandlesStyle, options);
	base.Draw(graphics, options);
public override void DrawHandles(IGraphics graphics, HandlesVisualStyle style, RenderOptions options)
For standard nodes you could draw handles in the background by handling DrawBackground event and calling Selection.Draw:
private void diagram_DrawBackground(object sender, DiagramEventArgs e)
	diagram.Selection.Style = SelectionStyle.SelectionHandles;
	diagram.Selection.Draw(e.Graphics, new RenderOptions());
but then you will have to stop standard handle rendering in some way, e.g. by assigning transparent brushes to ActiveItemHandlesStyle and SelectedItemHandlesStyle.
j poz
Reply #2 - Jul 29th, 2014 at 8:13pm
This works, except that now the mouseover does not show the handles..
Reply #3 - Jul 30th, 2014 at 8:26am
This should show the mouse-over handles too:
	var view = options.TargetView as DiagramView;
	if (view != null && view.AutoHandlesItem == this ||
	else if (Selected)
