Normal Topic CustomLink drawing on bezier curves (Read 2164 times)
j poz
Sep 3rd, 2014 at 10:26pm
I want to use customdraw on links using the bezier shape. More specifically, I want to draw a sort of 'border' around a diagram link so that it looks like it is three stripes (one color in the middle and two on the outside). How can I accomplish this?
Re: CustomLink drawing on bezier curves
Reply #1 - Sep 4th, 2014 at 7:40am
Try this:
private void diagram_DrawLink(object sender, DrawLinkEventArgs e)
	if (e.Shadow || e.Link.Shape != LinkShape.Bezier)
		return;
	var points = e.Link.ControlPoints.GetArray();
	using (var borderPen = new System.Drawing.Pen(Color.Red, 1 /* mm */))
		e.Graphics.DrawBeziers(borderPen, points);
	using (var stripePen = new System.Drawing.Pen(Color.Beige, 0.4f  /* mm */))
		e.Graphics.DrawBeziers(stripePen, points);
j poz
Reply #2 - Sep 5th, 2014 at 8:02pm
That worked, thank you.
