Normal Topic Container node caption not being set (Read 3388 times)
Al
Sep 4th, 2014 at 7:52am
Hi, I am creating a container like this:
Code (Javascript)
            var containerNode = diagram.getFactory().createContainerNode(bounds);
            containerNode.Caption = 'abc';
but the caption does not get set (btw the 'Caption' property is not documented, I found this in one of your online files)
Re: Container node caption not being set
Reply #1 - Sep 4th, 2014 at 8:01am
That looks like .NET code. In JavaScript version call the setText() method:
containerNode.setText('abc');
Check the http://mindfusion.eu/demos/jsdiagram/Containers.html example for more sample code for setting up containers.
Al
Reply #2 - Sep 4th, 2014 at 8:10am
That works, thank you. I am struggling a bit to find these methods because for eg. 'setText' doesn't appear for the 'ContainerNode' object in the help file.
Al
Reply #3 - Sep 4th, 2014 at 8:22am
One more thing - is it possible to centre the container caption?
Reply #4 - Sep 4th, 2014 at 9:06am
Right, our help generation system does not understand JavaScript inheritance at this time and won't show inherited methods. You could look for base DiagramNode and DiagramItem methods here:
http://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm?CC_T_MindFusion_Diagramm...
There's no official public method to specify alignment, buy you could set it through the Text object used to render the caption:
var cn = diagram.getFactory().createContainerNode(50, 50, 50, 50);
cn.setText("caption");
cn.text.textAlignment = Alignment.Center;
Al
Reply #5 - Sep 4th, 2014 at 11:26am
Sorted, thanks
