Normal Topic Diagram sizing & screen resolution (Read 2967 times)
Al
Sep 8th, 2014 at 9:42am
Hi, I have my diagram in the container as below where the div is sized on page load:
Code (Javascript)
    <div id="diagramContainer" style="font-family: arial; font-size: 12px; width=100%; overflow:scroll;" >
        <canvas id="diagram" >
        </canvas>
    </div>
    <script>
        document.getElementById("diagramContainer").style.height = (document.body.clientHeight - 80) + 'px';
        document.getElementById("diagramContainer").style.width = (document.body.clientWidth - 20) + 'px';
    </script>
I have removed all of my other code so after page load I do:
Code (Javascript)
diagram = Diagram.create($("#diagram")[0]);
And I get a diagram of some default size:
Code (Javascript)
diagram.getBounds()
c.Rect {x: 0, y: 0, width: 210, height: 297, transform: MindFusion.Drawing.Matrix…}
But after '$(document).ready(function () ' is finished, I end up with a massive diagram canvas much larger than the sizr above (no arrange or auto-resize etc).
If I try to diagram.setBounds() it becomes even more massive.
After some investigation it looks like the behaviour is caused by screen resolution. if I do diagram.setBounds(new Rect(0,0,100,100)) then my canvas gets set to 377x377 and doing diagram.getBounds still returns 100x100.
Basically I want to size my canvas to be the same as it's containing div - what would be the best way here?
« Last Edit: Sep 8th, 2014 at 10:49am by Al »
Al
Re: Diagram sizing & screen resolution
Reply #1 - Sep 8th, 2014 at 11:02am
I got the answer from another post on this forum:
Code (Javascript)
width = diagram.clientToDocLength(widthPx);
height = diagram.clientToDocLength(heightPx);
diagram.setBounds(new Rect(0, 0, width, height));
Reply #2 - Sep 8th, 2014 at 11:38am
Right, the default unit is millimeter. You can change it to pixel by calling diagram.setMeasureUnit(), but then you might also have to change many other size- and length- related property values.
