Normal Topic CustomAppointmentViewer (Read 3882 times)
SGS Software
Sep 29th, 2014 at 9:21am
I have a little problem.
I'm going to implement a custom draw with round corner.
Just starting from the "AdvancedItemDrawing" demo, in the ResourceView
doesn't works properly.
The rounded style apply, but I get a red "X" on white background on the screen when the first item disappear after an horizontal scroll.
Can anyone tell where I'm wrong or kindly give me another simple example with just round corners??
Thank you in advance!
Re: CustomAppointmentViewer
Reply #1 - Sep 29th, 2014 at 12:59pm
Do you get any error when the red "X" appears? If you do, can you post the stack trace here? Below you can download a simplified version of this sample. Do you experience problems using this version?
https://mindfusion.eu/_samples/_sample_AdvancedItemDrawing2.zip
SGS Software
Reply #2 - Sep 29th, 2014 at 4:43pm
Sorry, no error, just the X that cover all the scheduler and the form still run, either the scrollbar goes on!
Your example works, I'm going to "translate" it in VB.NET since I'm not experienced with C#...
I will try with VB and I let you know!
Anyway...thank you, meppy!
SGS Software
Reply #3 - Sep 30th, 2014 at 7:07am
Hi!
It seems to work!
Thank you
