Normal Topic Align nodes via top, bottom, left, etc.? (Read 3139 times)
Chris M
Oct 7th, 2014 at 3:34pm
I have been looking through the documentation and haven't been able to find if this functionality exists.
What I would like is to select multiple nodes and then choose whether to align them via their tops, bottom left, or right.  What steps would I need to take to achieve this?
Thanks.
Re: Align nodes via top, bottom, left, etc.?
Reply #1 - Oct 7th, 2014 at 4:08pm
Try the following methods:
void Align(
	Func<RectangleF, float> getter,
	Func<RectangleF, float, RectangleF> setter)
	var target = diagram.ActiveItem as DiagramNode;
	if (target != null)
		var alignedCoord = getter(target.Bounds);
		foreach (var node in diagram.Selection.Nodes)
			if (node == target)
				continue;
			node.Bounds = setter(node.Bounds, alignedCoord);
void AlignLeft()
	Align(
		r => r.Left,
		(r, coord) => new RectangleF(coord, r.Y, r.Width, r.Height));
void AlignTop()
	Align(
		r => r.Top,
		(r, coord) => new RectangleF(r.X, coord, r.Width, r.Height));
void AlignRight()
	Align(
		r => r.Right,
		(r, coord) => new RectangleF(coord - r.Width, r.Y, r.Width, r.Height));
void AlignBottom()
	Align(
		r => r.Bottom,
		(r, coord) => new RectangleF(r.X, coord - r.Height, r.Width, r.Height));
Chris M
Reply #2 - Oct 8th, 2014 at 4:11pm
Stoyo, thank you for your assistance with this question and the other I had posted. We are currently doing some prototyping with the trial to see if it meets our needs.
We are pleased with the documentation, functionality and the response for support so I believe we will be purchasing soon.
I do have another question but will post a new topic.
Thanks again!
