Normal Topic Styling of ContainerNodes (Read 2531 times)
benjamin huser
Oct 23rd, 2014 at 11:43am
Hi
we are currently working with the ContainerNode. Rightnow there are only some properties to define the style of the node (Background, Border etc.).
We would like to have full control over the style and, if possible, do this in XAML and not in the Draw-Method of the ContainerNode. Is this possible, and if yes, how?
Furthermore we would like to hide the disabled MovingHandles. Is this somehow possible?
Thanks for your help
Re: Styling of ContainerNodes
Reply #1 - Oct 23rd, 2014 at 4:11pm
If you mean specifying containers' appearance via Xaml template, you will have to add a Template property and return its instance from GetVisualChild override in a derived class, while also overriding Draw to prevent standard rendering:
<Style TargetType="{x:Type local:MyContainerNode}">
	<Setter Property="Template">
		<Setter.Value>
			<DataTemplate DataType="{x:Type local:MyContainerNode}">
				<Border
					BorderBrush="{Binding Stroke}"
					BorderThickness="1"
					Background="{Binding Brush}">
					<Grid>
						<Grid.RowDefinitions>
							<RowDefinition Height="Auto" />
							<RowDefinition Height="*" />
						</Grid.RowDefinitions>
						<TextBlock Height="{Binding CaptionHeight}" Text="{Binding Text}" />
					</Grid>
				</Border>
			</DataTemplate>
		</Setter.Value>
	</Setter>
</Style>
class MyContainerNode : ContainerNode
	static MyContainerNode()
		DefaultStyleKeyProperty.OverrideMetadata(
			typeof(MyContainerNode),
			new FrameworkPropertyMetadata(typeof(MyContainerNode)));
	/// <summary>
	/// Initializes a new instance of the MyContainerNode class.
	/// </summary>
	public MyContainerNode(Diagram parent)
		: base(parent)
		EnsureTemplate();
	public override void Draw(DrawingContext graphics,
		MindFusion.Diagramming.Wpf.RenderOptions options)
		// Draw the fold button
		DrawManipulators(graphics, false);
	protected override void OnAdd()
		base.OnAdd();
		EnsureTemplate();
	internal void EnsureTemplate()
		if (visual == null)
			OnTemplateChanged();
	public static DependencyProperty TemplateProperty = DependencyProperty.Register(
		"Template", typeof(DataTemplate), typeof(MyContainerNode),
		new FrameworkPropertyMetadata(null, OnTemplateChanged));
	static void OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs args)
		var node = (MyContainerNode)d;
		node.OnTemplateChanged();
	void OnTemplateChanged()
		var template = Template;
		if (template == null)
			return;
		if (visual != null)
			RemoveVisualChild(visual);
		visual = template.LoadContent() as FrameworkElement;
		if (visual != null)
			visual.DataContext = this;
			AddVisualChild(visual);
			InvalidateVisual();
	public DataTemplate Template
		get { return (DataTemplate)GetValue(TemplateProperty); }
		set { SetValue(TemplateProperty, value); }
	protected override Size MeasureOverride(Size availableSize)
		if (visual != null)
			visual.Measure(Bounds.Size);
		return Bounds.Size;
	protected override Size ArrangeOverride(Size finalSize)
		if (visual != null)
			visual.Arrange(new Rect(Bounds.Size));
		return Bounds.Size;
	protected override int VisualChildrenCount
		get { return visual == null ? 0 : 1; }
	protected override Visual GetVisualChild(int index)
		return visual;
	private FrameworkElement visual;
Set Diagram.ShowDisabledHandles = false to hide disable handles.
benjamin huser
Reply #2 - Oct 24th, 2014 at 8:42am
Hi Stoyan,
yes that was exactly what I wanted to achieve.
I implemented your solution and it is working perfect.
Thanks for your quick answer.
Reply #3 - Oct 29th, 2014 at 2:07pm
This version adds Template property to the base DiagramNode class:
https://mindfusion.eu/_beta/wpfdiag.3.2.zip
So now you can specify appearance through Xaml for all built-in node types by just adding Style with TargetType to the resource dictionary:
<ResourceDictionary>
	<Style TargetType="{x:Type diag:ContainerNode}">
			<Setter.Value>
				<DataTemplate DataType="{x:Type diag:ContainerNode}">....
Reply #4 - Oct 31st, 2014 at 10:43am
Here we have also added a NodeRenderer class that implements standard visualization of nodes, so using it you can now add extra Xaml elements on top of nodes without redefining all graphics:
		<Setter.Value>
				<Grid>
					<diag:NodeRenderer Node="{Binding}" />
					<Line X2="100" Y2="100" Stroke="Red" />
				</Grid>
			</DataTemplate>
		</Setter.Value>
	</Setter>
</Style>
