Normal Topic Setting some of the TableNode properties using WPF styling system throws an exception (Read 2089 times)
Kostya
Oct 28th, 2014 at 7:39am
I moved the diagram elements styles to a separate xaml file to skin them using the WPF styling system. Some properties are working in that way, but some throws an exception. For example, I would like to set the CaptionBrush for the TableNode. How to make it work in this style?
                    <Style TargetType="diag:TableNode">
                        <Setter Property="Stroke" Value="Red"/>
                        <Setter Property="StrokeThickness" Value="5"/>
                        <Setter Property="TextBrush" Value="Blue" />
                        <Setter Property="CaptionBackBrush" Value="Green"/>
                        <Setter Property="CaptionBrush" Value="White"/> // ------ exception
                    </Style>
-Kostya
Re: Setting some of the TableNode properties using WPF styling system throws an exception
Reply #1 - Oct 28th, 2014 at 9:19am
There's no dependency property corresponding to the CaptionBrush CLR property. It only wraps TextBrush and we keep it for API compatibility with our components for other platforms:
public Brush CaptionBrush
	get { return TextBrush; }
	set { TextBrush = value; }
So you can set the caption text brush in styles via the TextBrush property derived from DiagramItem.
Kostya
Reply #2 - Oct 29th, 2014 at 8:49am
Hi Stoyan,
Thanks much, it works!
-Kostya
