Normal Topic MF Canvas becomes blank in case of LAN (Read 5905 times)
shrinivas
Oct 30th, 2014 at 6:43am
I am generating MindFusion XML and loading on canvas It displays proper on locally but in case of LAN its not loading XML and canvas becomes blank.
Can you tell me reason behind this?.
Re: MF Canvas becomes blank in case of LAN
Reply #1 - Oct 30th, 2014 at 7:36am
What ClientSideMode are you using? Check if respective script or applet files are properly deployed, JDiagram.jar for JavaApplet mode and diagramming.js file for Canvas mode. For Canvas mode also check if browsers in your LAN support HTML5 (i.e. at least version 9 if using IE, and version 10 if also using SVG nodes).
shrinivas
Reply #2 - Oct 30th, 2014 at 8:15am
client side mode is Canvas and all files are properly deployed and IE version is 11 and which supports HTML5.
Do you need any other details?
Reply #3 - Oct 30th, 2014 at 11:48am
Check if there are any errors shown in the JavaScript console, and also try running with DiagramView.CanvasVirtualScroll set to true.
shrinivas
Reply #4 - Nov 11th, 2014 at 5:47am
I have generated VISIO for one program but which is not proper, i.e all links are overlapped as well as most of links are intersecting nodes. can you tell me reason behind this?
I have attached VISIO file as well as XML file from which I am generating VISIO.
If you need any other details please let me .
VISIO_Details.zip (Attachment deleted)
Reply #5 - Nov 11th, 2014 at 10:32am
DecisionLayout is designed to work with up to 4 links per node, you have 30-40 links for several nodes and some links are ignored. You have many links connecting to the end node, so one thing you could do is divide it into several end nodes, e.g. each having at most 7-8 incoming links.
Otherwise you could find the unprocessed diagonal links by checking for SegmentCount == 1 and different X/Y coordinates for StartPoint and EndPoint, and then call their Route() method to make sure they go around nodes.
Processed links overlap nodes when there's no enough space to fit all links at a LinkPadding distance between the nodes. You could either set larger HorizontalPadding and VerticalPadding to pull the nodes further apart, or set smaller LinkPadding to fit more links into that space.
shrinivas
Reply #6 - Nov 11th, 2014 at 1:15pm
This is no possible.
I am not generating this VISIO totally programatically, so please check first XML and then tell me  is it possible from XML and If not then I am going to post my code so please suggest changes in my code.
public bool GenerateVisioFile(string sXMLFilePath,string sDatabaseName="")
            string sVDXFilePath = "";
            Diagram dc = new Diagram();
            var visioDoc = new XmlDocument();
            VisioExporter vex = new VisioExporter();
            var diagDoc = new XmlDocument();
            clsDataBase objDataBase = new clsDataBase();
            try
                objDataBase.ReadSettingsXML(Application.StartupPath + "\\Settings.xml");
                if (ClsGlobal.gsDBName.ToUpper() == "TECHDB" && sDatabaseName.ToUpper() == "")
                { ClsErrorLog.ErrorLog("Started Processing files for VISIO", "", 2); }
                else
                    ClsGlobal.gsDBName = sDatabaseName;
                    objDataBase.InsertIntoSearch_Service_ErrorLog(System.Reflection.MethodBase.GetCu
rrentMethod().Name, "Message--Started Processing files for VISIO", DateTime.Now.ToString("dd-MMM-yyyy hh:mm:ss tt"));
                sVDXFilePath = System.IO.Path.GetDirectoryName(sXMLFilePath) + "\\" + System.IO.Path.GetFileNameWithoutExtension(sXMLFilePath) + ".VDX";
                dc.LoadFromXml(sXMLFilePath);
                dc.SaveToXml(sXMLFilePath);
                MindFusion.Diagramming.Layout.DecisionLayout dl = new MindFusion.Diagramming.Layout.DecisionLayout();
                dl.Orientation = MindFusion.Diagramming.Layout.Orientation.Vertical;
                dl.HorizontalPadding = 10;
                dl.VerticalPadding = 10;
                dl.Arrange(dc);
                vex.ExportInvisibleItems = false;
                vex.ExportTablesAsGroups = true;
                vex.DynamicsOff = true;
                vex.Export(dc, sVDXFilePath);
                visioDoc.Load(sVDXFilePath);
                dc.SaveToXml(diagDoc);
                var diagElement = visioDoc.ImportNode(diagDoc.DocumentElement, true);
                visioDoc.DocumentElement.AppendChild(diagElement);
                visioDoc.Save(sVDXFilePath);
                { ClsErrorLog.ErrorLog("End Processing files for VISIO", "", 2); }
                else
                { objDataBase.InsertIntoSearch_Service_ErrorLog(System.Reflection.MethodBase.GetCu
rrentMethod().Name, "Message--End Processing files for VISIO", DateTime.Now.ToString("dd-MMM-yyyy hh:mm:ss tt")); }
                return true;
            catch (Exception ex)
                ClsErrorLog.ErrorLog(System.Reflection.MethodBase.GetCurrentMethod().Name, ex.Message);
                return false;
            finally
                diagDoc = null;
I dont think It will solve my problem with changing HorizontalPadding and VerticalPadding Cz already I have given It as 10.
So please suggest some points,
Reply #7 - Nov 11th, 2014 at 6:47pm
You could set vex.DynamicsOff = false, possibly setting links' Shape to Cascading:
dl.Arrange(dc);
foreach (var link in dc.Links)
	link.Shape = LinkShape.Cascading;
var vex = new VisioExporter();
vex.DynamicsOff = false;
Then the links will be re-routed by Visio when it opens the file. They do not cross nodes in such case, but Visio does not try to pull them apart, so I think our version is more legible.
Alternatively, check the results of OrthogonalRouter applied after DecisionLayout. It will distribute all links in the available space between nodes, but still there are too many of them in some parts:
dl.Arrange(dc);
new OrthogonalRouter().Arrange(dc);
If you set them to 10 and LinkPadding stays set to 2, then you have place only for four links to pass between adjacent nodes without overlapping. Try increasing node spacing, decreasing link spacing, or both, and the link / node overlaps should disappear.
shrinivas
Reply #8 - Dec 9th, 2014 at 6:39am
I am have one XML having 125 nodes and 300 edges when I am trying to load on canvas Its taking near about 7 Mins. did you released any new version which takes minimum time to load this.
We had license version of Mindfusion diagramming if you need license details I will send you.
Thanks.
Reply #9 - Dec 10th, 2014 at 12:39pm
Please attach the XML file that takes 7 minutes to load or email it to support@mindfusion.eu.
