Normal Topic How to skip the styles serialization? (Read 2149 times)
bogdip
Oct 30th, 2014 at 2:21pm
We'd like the serialized diagram files not to include the diagram and diagram items styles. Is this possible to achieve?
The OnSerializeTag method is raised only for not-serializable properties so can't make use of it.
Bogdan
Re: How to skip the styles serialization?
Reply #1 - Oct 30th, 2014 at 3:19pm
It's not possible to prevent style serialization; you could remove the style elements from XML after serialization instead:
var xml = new XmlDocument();
diagram.SaveToXml(xml);
var nodeStyleElements = xml.SelectNodes(@"/Diagram/Nodes//Style");
foreach (XmlElement styleElement in nodeStyleElements)
	styleElement.ParentNode.RemoveChild(styleElement);
xml.Save(dlg.FileName);
Alternatively, try using a theme instead of individual styles if applying same styles to all items. Then you could temporarily set diagram.Theme = null before saving, and restoring it after that.
Reply #2 - Nov 5th, 2014 at 9:19am
This version lets you skip styles by setting diagram.XmlOptions.SerializeStyles = false before calling SaveToXml or LoadFromXml methods:
https://mindfusion.eu/_beta/wpfdiag.3.2.zip
bogdip
Reply #3 - Nov 6th, 2014 at 1:29pm
It works fine, thanks!
