Normal Topic PDF export with swim lanes not working (Read 3742 times)
David Adams
Nov 7th, 2014 at 4:09pm
When I use a diagram with swim lanes and use the pdf export, the swim lanes headers are not exported with the diagram. Image export works correctly.
Re: PDF export with swim lanes not working
Reply #1 - Nov 10th, 2014 at 1:56pm
This version will now export swimlanes if you set diagram.PrintOptions.EnableLanes = true;
https://mindfusion.eu/_beta/wpfdiag.3.2.zip
That has also been implemented for SvgExporter and WmfExporter.
David Adams
Reply #2 - Nov 10th, 2014 at 3:33pm
Thanks that helps, but a couple of things:
  1. The row headers are not printed
  2. The diagram now has an unlicensed watermark, but I need this in a production app and cant' have that showing.
Reply #3 - Nov 11th, 2014 at 10:08am
Row headers are exported in my test; please post your grid setup code or attach a saved diagram file. This version is still under development, the beta label is to remind you not to use in production.
Diagram.pdf (Attachment deleted)
David Adams
Reply #4 - Nov 11th, 2014 at 10:14am
I have attached the image export and the PDF export so you can compare. The header text is missing in the PDF.
It seems you are using the Gantt chart example, but I am following the Process Layout example.
DA
Programme.pdf (Attachment deleted)
Reply #5 - Nov 11th, 2014 at 5:13pm
This new build should export rotated headers correctly:
David Adams
Reply #6 - Nov 12th, 2014 at 9:25am
Thanks, that now prints the headers.
Any idea when we'll be able to get a licensed version of that build?
Reply #7 - Nov 12th, 2014 at 10:39am
We'll try to release it by the end of this month. If you are in a hurry, we should have a more stable build in a few days for use in production.
David Adams
Reply #8 - Dec 1st, 2014 at 11:40am
We can't see 3.2 in the downloads section. When will it be available? This is holding up our release.
DA
Reply #9 - Dec 2nd, 2014 at 6:41am
We are releasing in a few days. If you can' wait, you can find what should be a stable build on the PM page linked from top of the forum.
