Normal Topic Concern regarding sorting compatibility: LineChart (Read 6473 times)
marina
Nov 18th, 2014 at 7:57am
According to what I have noticed, the "POINT" related data is saved in separated collections:
- XAxis
- YAxis
- TooltipsCollection
- BrushCollection
This may lead to situation when only one collection is updated while the rest of the collections are left without change.
Please see below one example for of this behavior:
The "SortOrder" property (SortXDAta/SortYData) doesn't change the tooltips. After the sort occurs, there is no correlation between the tooltip data and the XAxis.
Can you please provide me additional places (related to the LineChart) that i should be aware of regarding this behaviour??
for example: Zoom calculations..?
Re: Concern regarding sorting compatibility: LineChart
Reply #1 - Nov 18th, 2014 at 11:10am
There are also pen and label collections. The labels are sorted together with data, we'll also sort tooltips for next release. We could add additional options for sorting pens and brushes if you want them bounds to data elements.
marina
Reply #2 - Nov 18th, 2014 at 11:45am
Currently we are sorting the data by ourselves because of that, but in general, why not to treat them all as one unit ?
Is there additional places where the data/tooltips/pens/brushes/labels is being sorted except of the "Sort" property is enabled?
Reply #3 - Nov 18th, 2014 at 12:07pm
They are sorted when you enable SortOrder or SortSeriesBy property, the former sorting elements in each series, and the latter sorting the overall order of series lines on screen. Brushes and pens are not sorted because we imagine you'd want to assign alternating colors and not reorder them with data, say if you want to repeat white/yellow/orange/white/yellow/etc... We'll add some flag that will let you sort them as well for next release.
marina
Reply #4 - Nov 19th, 2014 at 7:40am
thanks.
Flag is a good idea. Smiley.
Reply #5 - Nov 24th, 2014 at 12:23pm
You can find a new pre-release build on the PM page. Tooltips should be sorted automatically now. To sort brushes, enable the SortColor flag of SortOrder property:
lineChart.SortOrder = SortOrder.Ascending | SortOrder.SortColor;
