Normal Topic Selecting Links by Position (Read 4924 times)
dolfandon
Nov 25th, 2014 at 1:45pm
For some reason after upgrading the control (2.3) the following code doesn't work when the diagram is in read only mode. This used to work. It there some difference in the new version of the control or a different way to do this. BTW, it works for nodes, just not links.
CustomDiagramLink clickedItem4 = (CustomDiagramLink)currentDiagram.GetLinkAt(pastePoint, 5, true);
Re: Selecting Links by Position
Reply #1 - Nov 26th, 2014 at 11:46am
The true argument means it should skip locked links. If that read-only mode is implemented by setting links' Locked property, try calling GetLinkAt(... false) instead.
