Normal Topic RoundRectFactor doesn't work (Read 2154 times)
LanDocs
Nov 26th, 2014 at 9:12am
Hi! I use Diagram.RoundRectFactor, but it doesn't work. I attach a sample project. If change value in "numericUpDown1" its change value in "diagram1.RoundRectFactor", then it refreshes the diagram view, but nodes arcs doesn't changed. Its code mistake or components bug?
RoundRectFactorNotWork.zip (Attachment deleted)
Re: RoundRectFactor doesn't work
Reply #1 - Nov 26th, 2014 at 11:28am
This is used for nodes with a Shape property of type SimpleShape, i.e. TableNode, ContainerNode, TreeViewNode. For ShapeNodes, you will have to modify the shape definition, you can find an example here:
http://mindfusion.eu/Forum/YaBB.pl?num=1392678583/1#1
LanDocs
Reply #2 - Nov 26th, 2014 at 12:24pm
Stoyo wrote on Nov 26th, 2014 at 11:28am:
This is solved my problem, thank you very match.
