Normal Topic how to use the ShapeNode designed in Shape-Designer in own code? (Read 5718 times)
heyx
Dec 5th, 2014 at 9:01am
how to use the ShapeNode designed in Shape-Designer in own code and can I inherit the one of the shapes ?
thanks!
Re: how to use the ShapeNode designed in Shape-Designer in own code?
Reply #1 - Dec 5th, 2014 at 9:14am
You can save your shapes to a shape library xml file, load it using ShapeLibrary.LoadFromXml method and then assign the custom shapes to nodes by setting ShapeNode.Shape = Shape.FromId(...);
heyx
Reply #2 - Dec 8th, 2014 at 5:30am
hi Stoyan,
     I find that if a ues the Node by ShapeLibrary.LoadFromXml method, how can I set some Anchor Points on my mind ?
can I inherit some defeat shapes?
Reply #3 - Dec 8th, 2014 at 11:09am
We have a Shape.AnchorPattern property in some versions of the control that let you associate anchor points directly with shapes, but it's not available yet in WPF. For time being you could implement your own association, e.g. using a shape-id to AnchorPattern dictionary, and set node.AnchorPattern when node.Shape is set to one with known id from the the dictionary.
heyx
Reply #4 - Dec 9th, 2014 at 1:45am
hi Stoyan,
  I don't clearly know How to implement the Shape With my own AnchorPattern-points. Could you Show me the way more detailed. and I have attached my project.
  Thanks very much ! Smiley
EvSwitch_001.rar (Attachment deleted)
Reply #5 - Dec 10th, 2014 at 9:01am
If you will be creating custom types for different shapes as you have an EvRectangle node, you could set base.AnchorPattern in their constructors and don't change it anymore:
public EvRectangle()
	AnchorPattern = AnchorPattern.Decision2In2Out;
For ordinary ShapeNodes you could keep a dictionary mapping shape to anchor pattern identifiers and set node.AnchorPattern from NodeCreated:
private void OnNodeCreated(object sender, NodeEventArgs e)
	var node = e.Node as EvBaseNode;
	var shapeNode = e.Node as ShapeNode;
	if (node != null)
	else if (shapeNode != null)
		if (shapeAnchorPoints.ContainsKey(shapeNode.Shape.Id))
			var anchorPointsId = shapeAnchorPoints[shapeNode.Shape.Id];
			shapeNode.AnchorPattern = AnchorPattern.FromId(anchorPointsId);
Dictionary<string, string> shapeAnchorPoints = new Dictionary<string, string> {
	{ "Rectangle", "LeftInRightOut" },
	{ "Decision", "Decision1In3Out" }
We'll try to port the Shape.AnchorPattern property from our WinForms control for next release.
heyx
Reply #6 - Dec 11th, 2014 at 2:54am
hi Stoyan,
Thanks for you help, I can solve the problem on your way.
but I think the AnchorPattern.Regist method is necessary.
because the defeat AnchorPattern-points is so poor.
so I defined like this:
 public class EvDefaultNodeAnchorPoint
        private Dictionary<string, string> shapeAnchorPoints = new Dictionary<string, string>
            {"Ellipse", "Decision4In4Out"},
            {"RSave", "Decision4In4Out"},
            {"Rectangle", "Decision4In4Out"},
            {"Alternative", "Decision4In4Out"},
            {"Arrow7", "Decision4In4Out"},
            {"Cloud", "Decision4In4Out"},
            {"ConeDown", "Decision4In4Out"},
            {"ConnectedIssues", "Decision4In4Out"},
            {"CreateRequest", "Decision4In4Out"},
            {"Cross", "Decision4In4Out"},
            {"Cylinder", "Decision4In4Out"},
            {"Database", "Decision4In4Out"},
            {"DataTransmition", "Decision4In4Out"},
            {"DividedEvent", "Decision4In4Out"},
            {"Octagon", "Decision4In4Out"}
        public Dictionary<string, string> ShapeAnchorPoints
            get { return shapeAnchorPoints; }
        private AnchorPattern decision4In4Out =
            new AnchorPattern(new AnchorPoint[]
                new AnchorPoint(50, 0, true, true, MarkStyle.None),
                new AnchorPoint(0, 50, true, true, MarkStyle.None),
                new AnchorPoint(50, 100, true, true, MarkStyle.None),
                new AnchorPoint(100, 50, true, true, MarkStyle.None)
        public AnchorPattern Decision4In4Out
            get { return decision4In4Out; }
Reply #7 - Dec 11th, 2014 at 8:42am
You could pass the "Decision4In4Out" id to AnchorPattern constructor and that isntance will be automatically registered and later returned by AnchorPattern.FromId.
Reply #8 - Jan 9th, 2015 at 3:09pm
This version adds Shape.AnchorPattern property:
https://mindfusion.eu/_beta/wpfdiag.3.2.1.zip
Once you assign your anchor pattern to shapes, you won't have to set nodes' own AnchorPattern anymore. I.e. when node.AnchorPattern is null, the control will automatically use node.Shape.AnchorPattern instead.
heyx
Reply #9 - Jan 27th, 2015 at 1:34am
Thanks Stoyan, I will try in my code.
