Normal Topic Can I add more templates and primitives to the Shape designer? (Read 1819 times)
Centron
Feb 11th, 2015 at 2:12pm
As the question says. What are my options to extend the functionality of the designer in terms of pre-defined shapes? Can I somehow import all pre-installed shapes into the designer to use them as templates, or am I limited to the square, diamond, and oval?
Re: Can I add more templates and primitives to the Shape designer?
Reply #1 - Feb 12th, 2015 at 8:39am
There's no support for custom elements in the designer at this time. If you need to provide users with templates as a starting point only, you could add some ShapeNodes to a NodeListView and import their shape upon drag-and-drop:
<diag:ShapeDesigner
	x:Name="designer"
	Height="200" Width="300"
	AllowDrop="True"
	DragOver="OnDesignerDrag"
	Drop="OnDesignerDrop" />
private void OnDesignerDrag(object sender, DragEventArgs e)
	e.Effects = DragDropEffects.Copy;
	e.Handled = true;
private void OnDesignerDrop(object sender, DragEventArgs e)
	var draggedNode = (DraggedNode)e.Data.GetData(typeof(DraggedNode));
	var shapeNode = (ShapeNode)draggedNode.Node;
	designer.ImportShape(shapeNode.Shape);
	e.Handled = true;
We are improving the designer for upcoming release (e.g. to show grid and allow defining anchor points), and could also implement a method for adding new templates if it will help you. The templates in the designer's palette are lists of ElementTemplate -derived objects, so you will be able to add only predefined Shape.Outline lists there instead of full shape's definitions (including decoration lines and filled decorations).
The Primitives palette shows single ElementTemplate -derived objects, and if you need to add to it you'd have to implement both a new ElementTemplate class and a companion builder class used by the designer to represent the element.
