Normal Topic How to Create User-defined ShapeNode when Click in the diagram? (Read 1172 times)
heyx
Dec 16th, 2014 at 6:33am
hi,I Create several User-defined ShapeNode in my Code and I want to use the toolbar that when I click one button in toolbar(it's mean the related shapenode shoud be created after I click in the diagram)
For example:
I click the "Add New EvElectronicSwitch" button in toolbar,and move the mouse into the diagram and click.then the
"EvElectronicSwitch" Shapenode should be create at the mouse‘s position.
Do you know how to do this?and I attach my project to you for asking for you help. thanks
EvSwitch_002.rar (Attachment deleted)
Re: How to Create User-defined ShapeNode when Click in the diagram?
Reply #1 - Dec 16th, 2014 at 8:58am
If using standard ShapeNodes, you could set Diagram.DefaultShape from toolbar click handlers, and call Factory.CreateShapeNode from Diagram.Clicked handler:
Size newNodeSize = new Size(100, 100);
private void OnDiagramClicked(object sender, DiagramEventArgs e)
	diagram.Factory.CreateShapeNode(
		e.MousePosition - new Vector(newNodeSize.Width, newNodeSize.Height) / 2,
		newNodeSize);
// in toolbar click
diagram.DefaultShape = Shape.FromId("EvElectronicSwitch");
If using custom node types, you could keep a prototype node for each type, set a current prototype from toolbar handlers, and handle Diagram.Clicked by call Diagram.Nodes.Add(currentPrototype.Clone());
