Normal Topic Shapenode are not bound to diagram.bound property (Read 5954 times)
Pratik
Dec 19th, 2014 at 9:24am
Plz reply
Re: Shapenode are not bound to diagram.bound property
Reply #1 - Dec 19th, 2014 at 11:51am
You could enable Diagram.AutoResize to make the diagram grow automatically when users drag nodes outside its boundaries. Or otherwise handle the NodeModifying validation event and set e.Cancel = true to prevent users from moving nodes beyond diagram edges when diagram.Bounds does not contain node.Bounds.
Pratik
Reply #2 - Dec 19th, 2014 at 12:16pm
I used image map and the version which i used does not e.cancel option
Reply #3 - Dec 19th, 2014 at 2:14pm
It's raised in ImageMap mode too since version 3.0.1, as long as you set EnableItemsDOM:
    <ndiag:DiagramView runat="server"
		ID="diagramView"
		ClientSideMode="ImageMap"
		NodeModifyingScript="onNodeModifying"
		EnableItemsDOM="true"
        Width="800px" Height="500px" >
    </ndiag:DiagramView>
    <ndiag:InteractivityExtender runat="server" TargetControlID="diagramView" />
    </form>
</body>
<script type="text/javascript">
	function onNodeModifying(sender, args)
		//alert("mod");
		var nodeRight = args.get_bounds().right();
		var nodeBottom = args.get_bounds().bottom();
		var viewDiv = sender.get_element();
		if (nodeRight > view.scrollWidth || nodeBottom > view.scrollHeight)
			args.set_cancel(true);
Pratik
Reply #4 - Dec 23rd, 2014 at 5:05am
Shapes.BpmnStartMessage.TextArea
throws exception "index was outside the bound arrays"
in image map mode
Reply #5 - Dec 23rd, 2014 at 1:23pm
What does your code that uses Shapes.BpmnStartMessage.TextArea look like?
Pratik
Reply #6 - Dec 23rd, 2014 at 2:00pm
Display text out side the node
Reply #7 - Dec 23rd, 2014 at 6:32pm
Please post your .NET code that leads to exception.
Pratik
Reply #8 - Dec 24th, 2014 at 4:29am
Dim objShapeNode As ShapeNode = Nothing
objShapeNode = objDiagram.Factory.CreateShapeNode(2, 2, 20, 20)
objShapeNode.Shape = Shapes.Rectangle
objShapeNode.Brush = New LinearGradientBrush(Color.White, Color.White, 75)
            objShapeNode.Font = New Drawing.Font(New FontFamily("arial"), 9, FontStyle.Bold)
            objShapeNode.Transparent = True
            objShapeNode.Shape.TextArea = Shapes.BpmnStartMessage.TextArea
Reply #9 - Dec 26th, 2014 at 9:01am
That code does not throw any exceptions for me. Please post the exception stack trace.
