Normal Topic data source of diagram for js (Read 4073 times)
danyfeng2012
Dec 26th, 2014 at 3:41am
    I am from china,want to use this js control, but want to know something about data source of   diagram for js , as i know diagram for silverlight which contain the method named
LoadFromstring(xmlStr),   Do diagram for js  contais the same js method like : LoadFromstring(jsonStr);
   thanks waiting for answers
Re: data source of diagram for js
Reply #1 - Dec 26th, 2014 at 8:22am
There are the Diagram.toJson and Diagram.fromJson methods letting you save and load the diagram to/from string.
danyfeng2012
Reply #2 - Dec 26th, 2014 at 8:54am
Stoyo wrote on Dec 26th, 2014 at 8:22am:
thanks ,i got it.....
a  new question :i draw a shapeNode, diagram's bouds is
(0,0,2000,2000),and then i  set bounds(140,50,165,36) for the shapeNode, but the shapeNode shows too bigger,i want to know whether render unit is different. and i find the property  "measuerUnit" ,maybe There are relations with it?
Reply #3 - Dec 26th, 2014 at 9:08am
Right, the default MeasureUnit is millimeter, you could set it to pixel but then you will have to change other property values too, such as AdjustmentHandlesSize and font sizes.
danyfeng2012
Reply #4 - Dec 26th, 2014 at 9:16am
it is so complicated,i should change all the text fontsize!!!
danyfeng2012
Reply #5 - Dec 31st, 2014 at 1:19am
Stoyo wrote on Dec 26th, 2014 at 9:08am:
in reality,change the property measureUnit is enough
