Normal Topic ContainerNode moves when changing size (Read 2765 times)
Sim
Jan 7th, 2015 at 12:28pm
I'm implementing a feature where multiple ContainerNode objects can be placed inside one another to create a layered swim lane.
One part of this functionality is changing the size of the parent ContainerNode to fit the child ContainerNodes. However, something strange happens. When a second ContainerNode is added to the parent, the parent moves. The image which I have attached to this post contains an example. A parent ContainerNode is placed on the corner of another node and then a second child is added to the parent. This moves the parent, while the children stay in the right spot.
The code that is causing the issue is the following:
Code (C++)
public void ChildAdded()
    if (!this.OldBounds.IsEmpty)
        float totalHeight = 0.0f;
        foreach (DiagramNode connectedNode in this.SubordinateGroup.AttachedNodes)
            MyContainerNode connectedContainer = connectedNode as MyContainerNode;
            if (null != connectedContainer)
                totalHeight += connectedContainer.Bounds.Width;
        PointF location = new PointF(this.OldBounds.X, this.OldBounds.Y);
        SizeF size = new SizeF(totalHeight, this.OldBounds.Height);
        RectangleF bounds = new RectangleF(location, size);
        this.SetBounds(bounds, true, true);
This method is a part of the MyContainerNode class and the OldBounds property is a copy of the Bounds of the ContainerNode before the child was added. Note: the MyContainerNode objects are rotated 270 degrees, which is why 'totalHeight' actually containers the width of the children.
Using the code above, the Bounds.Location of the parent does not change when the second child is added.
If I remove the call 'this.SetBounds(bounds, true, true);'  the parent will not move.
What could be causing the parent lane to move?
Re: ContainerNode moves when changing size
Reply #1 - Jan 7th, 2015 at 2:29pm
The Bounds property specifies the rectangle coordinates for 0 rotation angle, so you will actually have to also change Bounds.Location if you want the corner to remain at same position after rotation center moves (due to size change). Our auto-sizing code already takes this into account, so try this instead:
container.AutoGrow = true;
container.Margin = 0;
container.UpdateBounds();
That should not change parent's top-left position if the newly added node is aligned below old nodes.
Sim
Reply #2 - Jan 7th, 2015 at 3:03pm
I am currently using MindFusion.Diagramming version 6.1.2 which does not seem to support the AutoGrow property just yet. Would it be possible to keep the corner in the same position in version 6.1.2?
Reply #3 - Jan 8th, 2015 at 11:51am
Try this:
// 270 degree rotation bring Bounds top-right point to top-left
var corners = new[]
	new PointF(OldBounds.Right, OldBounds.Top),
	new PointF(OldBounds.Left, OldBounds.Bottom)
var rotation = new Matrix();
rotation.RotateAt(270, GetCenter());
rotation.TransformPoints(corners);
corners[1].Y = corners[0].Y + totalHeight;
// rotate back around new center to get 0-degree corner locations
var inverse = new Matrix();
inverse.RotateAt(-270,
	InternalUtils.MidPoint(corners[0], corners[1]));
inverse.TransformPoints(corners);
RectangleF bounds = RectangleF.FromLTRB(
	corners[0].X, corners[0].Y, corners[1].X, corners[1].Y);
