Normal Topic Export issue - missing link (Read 3501 times)
choohj70
Jan 9th, 2015 at 7:31am
When I try to export diagram (pdf and svg) with polyline links, the result rendering has only first segments of the links drawn and the rest is missing (see attached sample).
Is this a bug?
Re: Export issue - missing link
Reply #1 - Jan 9th, 2015 at 2:49pm
I could not reproduce that; please attach XML file for your diagram.
choohj70
Reply #2 - Jan 10th, 2015 at 8:12am
attaching xml's and resulting exports
Reply #3 - Jan 10th, 2015 at 3:34pm
It looks like a bug, for time being you can work around it by disabling crossing arcs or by calling UpdateFromPoints method before exporting:
protected void OnExport(object sender, EventArgs e)
	foreach (var link in diagramView.Diagram.Links)
		link.UpdateFromPoints(false, true);
	//diagramView.Diagram.LinkCrossings = LinkCrossings.Straight;
	var exporter = new PdfExporter();
	exporter.Export(diagramView.Diagram, "test.pdf");
choohj70
Reply #4 - Jan 12th, 2015 at 6:01am
It works!
Thank you.
