Normal Topic Can we change a color of a speicific date cell? (Read 5722 times)
Safi Mustafa
Jan 17th, 2015 at 8:02am
I am currently windows 2003 theme in which currently I am working on month view setting.I want to have Date on top left corner with an image on right and appointment below.So what I did is that I set header size property and removed its bottom border.
So what I have acheived so far is attached in file.
My problem is that I want to have full cell color same that is green for daily and red for recurring, with date at left and a custom added icon on top right corner.
Is there any way it can be done?
« Last Edit: Jan 17th, 2015 at 4:25pm by Safi Mustafa »
Re: Can we change a color of a speicific date cell?
Reply #1 - Jan 19th, 2015 at 8:51am
Check out the attached sample. It uses a custom presenter for the calendar cells. Cells are colored red or green depending on whether the items contained in them are regular or recurring. The cells also display a small icon in their top left corner.
Let me know if this helps.
Safi Mustafa
Reply #2 - Jan 19th, 2015 at 7:46pm
Thank you so much meppy. One more thing can you tell me how to avoid coloring padding days in custom cell presenter?
Reply #3 - Jan 20th, 2015 at 7:01am
In the UpdateBackground method, change the following line:
if (items.Count == 0 || IsPadding)
	ClearValue(CustomBackgroundProperty);
If the cell contains no items or is a padding cell, use the default background.
Safi Mustafa
Reply #4 - Jan 20th, 2015 at 7:55pm
Is padding Doesnt work and secondly attached Image is shown in all the cells.I wanted to show it in just the cell a reccurence occur, so I added it in only that cell. But the problem is that even if the reccurence is daily and is finished in that cell it is shown in every month on the same date cell it was supposed to show in some specific month
Safi Mustafa
Reply #5 - Jan 20th, 2015 at 8:48pm
I added another property named as CellHeadIcon just like custom background and binded it with image.Now what I do is that I Set this to null at the very start of updateBackground Function and set it where I need it so that it don't repeat in other months.And for padding I added this code
if (Calendar.CurrentView == CalendarView.SingleMonth)
                    var FirstDayOfNextMonth = new DateTime(Calendar.Date.Year, Calendar.Date.Month, 1).AddMonths(1);
                    var FirstDayOfThisMonth = new DateTime(Calendar.Date.Year, Calendar.Date.Month, 1);
                    if (items[0].StartTime < FirstDayOfThisMonth || items[0].StartTime >= FirstDayOfNextMonth)
                        return;
