Normal Topic Preventing links from jumping among anchors? (Read 1854 times)
stefski
Feb 2nd, 2015 at 7:09pm
Hello Guys,
I am trying to make our DiagramLinks stick to the AnchorPoints, to which the user has attached them. Currently, given that we have defined a set of AnchorPoints per DiagramNode, and having connected two DiagramNodes with a DiagramLink, if the user moves one node around the other, the link end-points will "jump" among the anchors as if to seek the shortest link length.
Is there a simple approach to make the link ends stay on the anchor points they have been assigned to? We have a requirement to let the user manually move the link ends if he/she finds it necessary, i.e. preventing the automatic re-assignment.
Any flags configuration or notification I might have missed?
Kind regards
Steffen Skov
OLGA Application Architect
Schlumberger Information Solutions AS
Kind regards
Steffen Skov
Re: Preventing links from jumping among anchors?
Reply #1 - Feb 2nd, 2015 at 9:01pm
Set links' Dynamic property to false. If using auto-routing, you might have to change RoutingOptions.Anchoring value.
stefski
Reply #2 - Feb 6th, 2015 at 2:53pm
Hi Stoyan,
thank you very much for your quick answer! Following your suggestion, we found a place in our code, where the Dynamic flag was set to true, we corrected it, and the whole thing worked l like a charm. Grin
Have a great weekend!
Kind regards
Steffen Skov
