Normal Topic Problem selecting Link inside ContainerNode (Read 1523 times)
Viev
Feb 6th, 2015 at 5:49am
Hi all,
I have a problem selecting a Link inside a ContainerNode.
The ContainerNode is selected instead of the link.
e.g. On one windows form the following works fine, on another windows form testing inside DiagramView.MouseUp returns different results:
Dim loNode As DiagramNode
loPoint = Diagram.PixelToUnit(e.Location)
loObject = Diagram.GetItemAt(loPoint, False)
Inside my first form, the above will return the Link clicked on to loObject.
Inside my second form, the above will return the ContainerNode that the Link is inside of.
I don't know what I'm missing. I've tried setting ZTop to the Link and ZBottom to the ContainerNode. I've searched, unsuccessfully for a member of Diagram, or DiagramView that will select links before other DiagramNodes (unless I missed something).
Any ideas most welcome. At the end of the day I would like to select a Link inside a ContainerNode.
kind regards
V
Re: Problem selecting Link inside ContainerNode
Reply #1 - Feb 6th, 2015 at 6:53am
Set the Diagram.HitTestPriority property.
