Normal Topic Manually create Database diagram with relationship (Read 5899 times)
bruser
Feb 10th, 2015 at 4:06am
Hello guys, I have this problem while using these code to manually create a relationship between 2 entities. The code is:
var link = new DiagramLink(diagram);
link.Origin = e1;
link.Destination = e2;
link.OriginAnchor = 0;
link.DestinationAnchor = 1;
diagram.Links.Add(link);
The Destination point of the relationship is correct but the Original point is always stuck at the top left of Window form, as in this photo Cheesy Please help.
Re: Manually create Database diagram with relationship
Reply #1 - Feb 10th, 2015 at 9:16am
The link.*Anchor properties will do nothing if you haven't set nodes' AnchorPattern. If you need to specify which rows should get connected, set the OriginIndex and DesintationIndex properties instead, or pass them as arguments to CreateDiagramLink method:
link.Origin = e1;
link.OriginIndex = 0;
link.DestinationIndex = 0;
//diagram.Factory.CreateDiagramLink(e1, 0, e2, 0);
bruser
Reply #2 - Feb 11th, 2015 at 12:55am
It helps, thank you very much  Wink, one more question if I can ask here. How can I define the distance between 2 entities?
Reply #3 - Feb 11th, 2015 at 9:14am
If you need to arrange the tables automatically, try setting NodeDistance / LayerDistance properties in some of the layout classes:
var layout = new LayeredLayout();
layout.Orientation =
	MindFusion.Diagramming.Layout.Orientation.Horizontal;
layout.LayerDistance = 40;
layout.Arrange(diagram);
bruser
Reply #4 - Feb 12th, 2015 at 1:26am
Thank you for your reply, could you also tell me how to change color for the diagramLink arrows? Also is there anyway to disable delete control via keyboard delete button for the diagramLink?
Reply #5 - Feb 12th, 2015 at 8:01am
You can change link's colors by setting its Pen, HeadPen and Brush properties. Set DiagramView.DelKeyAction = None to disable deleting items altogether, or handle LinkDeleting validation event to prevent deleting links only.
bruser
Reply #6 - Feb 16th, 2015 at 11:54pm
Now I have another problem, the this.diagram.Print() won't work, it said does not contain a definition for 'Print'. Am I missing something?  Embarrassed
Reply #7 - Feb 17th, 2015 at 8:00am
Call DiagramView.Print() instead of Diagram.Print().
bruser
Reply #8 - Feb 18th, 2015 at 1:47am
It's a little blurring but least it worked, if you have any advice to improve the quality please tell me. Thank you for your support so far  Smiley
Reply #9 - Feb 18th, 2015 at 11:05am
What's blurry exactly - graphics on printed page? If printing in gray-scale you will get some patterns printed instead of colors and gradients, which will make text harder to read, so you could try disabling brushes to get only text and frame lines:
diagramView.PrintOptions.EnableInterior = false;
diagramView.PrintOptions.EnableShadows = false;
You might also try changing anti-aliasing options temporarily before printing:
diagramView.SmoothingMode = SmoothingMode.None;
diagramView.TextRenderingHint = TextRenderingHint....;
