Normal Topic jQuery Custom nodes (Read 4084 times)
dittu
jQuery Custom nodes
Feb 13th, 2015 at 6:33am
I'm using jQuery instead of MicrosoftAjax. While trying out Tutorial 3 in samples (to create custom nodes), I'm facing issues on commands like
OrgChartNode.registerClass
OrgChartNode.initializeBase
Has anyone implemented custom nodes with jQuery, how to registerClass/initializeBase etc. Please provide some help by pasting code snippet .
Thanks in advance
Re: jQuery Custom nodes
Reply #1 - Feb 13th, 2015 at 8:15am
Use the following methods:
MindFusion.AbstractionLayer.registerClass(type, typeName, baseType, interfaceTypes);
MindFusion.AbstractionLayer.initializeBase(type, instance, baseArguments);
e.g.
var al = MindFusion.AbstractionLayer;
al.registerClass(OrgChartNode, "OrgChartNode", MindFusion.Diagramming.ShapeNode);
al.initializeBase(OrgChartNode, this, [parent]);
dittu
Reply #2 - Feb 13th, 2015 at 9:23am
Thanks Stoyan.
I tried doing that, it went further but there are many more errors in replacing MicrosoftAjax with jQuery version of sample/tutorial3.
like:
$addHandlers issue while adding NodeImageLocation
undefined ...d.drawVM81:1 a.drawVM81:1 a.repaintjquery-1.7.1.js:814 jQuery.extend.proxy.proxy
your help on this is highly appreciated.
Reply #3 - Feb 13th, 2015 at 9:50am
Here's a jQuery version of the tutorial.
Tutorial3JQ.zip (Attachment deleted)
dittu
Reply #4 - Feb 25th, 2015 at 11:19am
Thanks. Smiley
It worked by removing margin.
Reply #5 - Feb 25th, 2015 at 11:28am
If you mean the Text.margin field, in latest version of the control its type has been changed to Thickness, and you can set it like this:
var Thickness = MindFusion.Drawing.Thickness;
this.text.margin = new Thickness(1, 1, 1, 1);
