Normal Topic Need assistance to implement a Strip on Scheduling Grid (Read 6439 times)
rajadorai
Feb 19th, 2015 at 8:22am
I was just trying to implement a Purple Strip like in the attached screen of Scheduling Grid.
Can someone assist on that Please  Sad?
Re: Need assistance to implement a Strip on Scheduling Grid
Reply #1 - Feb 19th, 2015 at 9:21am
You can do this by using custom drawing. More specifically, set the Calendar.CustomDraw property to CustomDrawElements.TimetableCell and handle the Calendar.Draw event. The following sample provides a complete solution:
https://mindfusion.eu/_samples/_sample_TimetableStrips.zip
rajadorai
Reply #2 - Mar 11th, 2015 at 10:13am
Thanks for providing me the assistance. The code you have provided me helped us to develop the Purple strip across the grid, when there are NO COLUMNS.
We can able to draw the Purple strip across the grid only when there are rows stretched across.
Please let us know, whether we can develop the Purple strip even when there are rows and columns on the Calendar Grid. Thanks in advance.
Reply #3 - Mar 11th, 2015 at 12:03pm
If you need to display the stripes on top of appointments, you can collect the areas that need to be filled and perform the actual drawing later, in a Calendar.Paint handler. The modified version of the sample illustrates how:
https://mindfusion.eu/_samples/_sample_TimetableStrips2.zip
Let me know if this helps.
rajadorai
Reply #4 - Mar 12th, 2015 at 9:37am
Thanks! Even if we collect the entire areas that need to be filled using the Calendar.Paint handler, the fill is limited to only a single cell in the Calendar grid. I have attached the screen shot.
I need to fill in all the cells using the Calendar.Paint handler.
Also you have provided the sample code for "Timetable Strips" which uses “Customdrawelements.timetablecell”, but we are in need of “Customdrawelements.scheduleitem “. Please assist. Thank you!
Reply #5 - Mar 12th, 2015 at 10:25am
Have you tried the attached sample? It should properly fill all the cells associated with the specified time intervals. The sample deliberately uses the TimetableCell element for this purpose. If you use the ScheduleItem element, the custom drawing code will not be executed for columns that do not contain appointments.
