Normal Topic How do I import diagrams with custom nodes? (Read 1785 times)
Centron
Feb 25th, 2015 at 9:20am
I create diagrams including my own custom node class. When I try to load that diagram in another project, I get an InvalidOperationException with the message "Failed to instantiate item of type 'my:DiagramCustomNode'."
What do I have to do so the importing diagram knows about that missing class?
I save and load the diagram document with SaveToString and LoadFromString.
This is my custom node class:
    public class DiagramCustomNode : TemplatedNode
        static DiagramCustomNode()
            DefaultStyleKeyProperty.OverrideMetadata(
                typeof(DiagramCustomNode), new FrameworkPropertyMetadata(typeof(DiagramCustomNode)));
        public DiagramCustomNode()
        // Required for creating nodes by dragging them from the NodeListView
        public DiagramCustomNode(DiagramCustomNode prototype)
            : base(prototype)
            Title = prototype.Title;
            FullName = prototype.FullName;
            Image = prototype.Image;
        public string Title
            get { return (string)GetValue(TitleProperty); }
            set { SetValue(TitleProperty, value); }
        public static readonly DependencyProperty TitleProperty = DependencyProperty.Register(
            "Title",
            typeof(string),
            new PropertyMetadata(""));
        public string FullName
            get { return (string)GetValue(FullNameProperty); }
            set { SetValue(FullNameProperty, value); }
        public static readonly DependencyProperty FullNameProperty = DependencyProperty.Register(
            "FullName",
            typeof(string),
        public ImageSource Image
            get { return (ImageSource)GetValue(ImageProperty); }
            set { SetValue(ImageProperty, value); }
        public static readonly DependencyProperty ImageProperty = DependencyProperty.Register(
            "Image",
            typeof(ImageSource),
            new FrameworkPropertyMetadata(null, FrameworkPropertyMetadataOptions.AffectsRender));
        // serialization support for custom properties
        protected override void SaveToXml(XmlElement xmlElement, XmlPersistContext context)
            base.SaveToXml(xmlElement, context);
            context.WriteString(Title, "Title", xmlElement);
            context.WriteString(FullName, "FullName", xmlElement);
            context.WriteImage(Image, "Image", xmlElement);
        protected override void LoadFromXml(XmlElement xmlElement, XmlPersistContext context)
            base.LoadFromXml(xmlElement, context);
            Title = context.ReadString("Title", xmlElement);
            FullName = context.ReadString("FullName", xmlElement);
            Image = context.ReadImage("Image", xmlElement);
        // undo and redo support
        protected override DiagramItemProperties CreateProperties()
            return new DiagramCustomNodeProperties();
        protected override void SaveProperties(DiagramItemProperties props)
            base.SaveProperties(props);
            var state = (DiagramCustomNodeProperties)props;
            state.Title = Title;
            state.FullName = FullName;
            state.Image = Image;
        protected override void RestoreProperties(DiagramItemProperties props)
            base.RestoreProperties(props);
            Title = state.Title;
            FullName = state.FullName;
            Image = state.Image;
    public class DiagramCustomNodeProperties : DiagramNodeProperties
        internal string Title;
        internal string FullName;
        internal ImageSource Image;
Re: How do I import diagrams with custom nodes?
Reply #1 - Feb 25th, 2015 at 11:11am
You will have to add the custom class to that other project too, possibly by implementing it in a shared assembly, and also call Diagram.RegisterItemClass(...  "my:DiagramCustomNode") before calling LoadFromString.
