Normal Topic how to use keyDonw event to implement Copy and Paste ? (Read 3211 times)
heyx
Mar 4th, 2015 at 7:34am
hi,
I use KeyDown like this:
    if ((Keyboard.Modifiers & ModifierKeys.Control) == ModifierKeys.Control && e.Key == Key.C)
        CopyItems();
    if ((Keyboard.Modifiers & ModifierKeys.Control) == ModifierKeys.Control && e.Key == Key.V)
        PasteItems();
but, it never execute the CopyItems and PasteItems method?
do the Diagram have handled the Ctrl-Key?
Re: how to use keyDonw event to implement Copy and Paste ?
Reply #1 - Mar 4th, 2015 at 8:27am
WPF executes ApplicationCommands.Copy / Paste for these key combinations, and the diagram handles them by calling its CopyToClipboard and PasteFromClipboard methods. If you want to use your methods instead, you can override the diagram handlers like this:
diagram.CommandBindings.Add(
	new CommandBinding(ApplicationCommands.Copy, (sender, args) => CopyItems()));
heyx
Reply #2 - Mar 4th, 2015 at 9:02am
hi Stoyan,
  my CopyItems and PasteItems has no parameter, so I can't use your code.
Reply #3 - Mar 4th, 2015 at 10:35am
My code also calls CopyItems() without arguments if you look above, I don't know why you have added ones. The (sender,args) parameters are for the lambda expression set as handler of Copy command and you can ignore them, you don't have to pass them to CopyItems. If you have a 'sender' argument passed to outer method from where you call Bindings.Add, you'll only have to rename the inner one, e.g. call it just 's'.
heyx
Reply #4 - Mar 5th, 2015 at 1:51am
hi Stoyan,
I have fixed my errors using below code.
But when I move some of nodes on Diagram.It trigger CustomerCopyItems method everytime.
is there some properties of Diagram which I have not setted its value?
thanks.
 void CustomerCopyItems(object sender, ExecutedRoutedEventArgs e)
     CopyItems();
void CustomerPasteItems(object sender, ExecutedRoutedEventArgs e)
     PasteItems();
Reply #5 - Mar 5th, 2015 at 9:06am
The diagram won't call your methods on its own. Check if you aren't calling them from some event handlers, such us OnMouseButtonUp or OnNodeModified. E.g. add breakpoints on the CopyItems() and PasteItems() lines, and see what other methods are shown in the call-stack window when the breakpoints hit.
