Normal Topic Custom Node with multiple images and texts (Read 5463 times)
dittu
Mar 11th, 2015 at 12:20pm
Hi Stoyo,
How can I have multiple image and text areas in my custom node. And are there overloaded methods to setText and imageLocations to do so?
Thanks in advance.
Re: Custom Node with multiple images and texts
Reply #1 - Mar 11th, 2015 at 4:44pm
Check the OrgChartNode implementation from tutorial 4; it adds several MindFusion.Drawing.Text and MindFusion.Drawing.Image objects to the node's content. Alternatively, you could base your custom nodes on TableNode class and display images and texts in separate table cells (see SpanningCells example).
dittu
Reply #2 - Mar 16th, 2015 at 7:28am
Thanks Stoyo for your response. I tried using SpanningCells, but am not able to set the cell borders to transparent. I want to keep frame border and remove all the internal borders so as to look one node without cells. Is this possible?
Again Thanks for your help.
Reply #3 - Mar 16th, 2015 at 10:11am
This version adds TableNode.CellFrameStyle property:
https://mindfusion.eu/_beta/jsdiag231.zip
You can now hide cell borders like this:
var CellFrameStyle = MindFusion.Diagramming.CellFrameStyle;
table.setCellFrameStyle(CellFrameStyle.None);
ashwini
Reply #4 - Mar 16th, 2015 at 12:07pm
Hi Stoyo,
We tried CellFrameStyle to None - to hide cell border.
But it is not working, still it is showing cell border.
Do we need to set any other property to work this.
Ashwini
Reply #5 - Mar 16th, 2015 at 12:28pm
What does your code look like?
ashwini
Reply #6 - Mar 17th, 2015 at 9:43am
Hi Stoyo,
Sorry I tried it again. It is working. Thanks a lot for your help  Smiley
Ashwini
