Normal Topic Custom Table node creation (Read 2100 times)
Santosh
Mar 27th, 2015 at 10:03am
I had one query related to custom table node. I want to add custom attributes to table node. How to achieve that? I was able to do the same using custom node. But I need table nodes.
I need something similar for table node.
Custom Node Approach:
var Diagram = MindFusion.Diagramming.Diagram;
var Behavior = MindFusion.Diagramming.Behavior;
var AbstractionLayer = MindFusion.AbstractionLayer;
var ElementNode = function (parent)
    AbstractionLayer.initializeBase(ElementNode, this, [parent]);
ElementNode.prototype =
    //Defined custom attributes here
   setMyAttribute: function(value){
        this.myAttribute = value;
   getMyAttribute: function(){
        return this.myAttribute;
Re: Custom Table node creation
Reply #1 - Mar 27th, 2015 at 11:43am
If by custom nodes you mean ones derived from ShapeNode as in tutorials, you can do the same with TableNodes too, just replace the base class in registerClass call, e.g.:
OrgChartNode.registerClass("OrgChartNode", MindFusion.Diagramming.TableNode);
