Normal Topic How to Rotate the Default shapenode? (Read 2023 times)
heyx
Apr 1st, 2015 at 3:08am
hi,
I crate a Default ShapeNode use this code and I set it's RotationAngle = 90.but the node don't rotate.
            ShapeNode shapeNode = new ShapeNode();
            shapeNode.Shape = Shapes.Rectangle;
            shapeNode.Text = "AAAAA";
            shapeNode.TextAlignment= TextAlignment.Center;
            shapeNode.TextVerticalAlignment= AlignmentY.Center;
            shapeNode.RotationAngle = 90;
            shapeNode.Bounds = new Rect(new Point(20,20),new Size(96,96));
            Diagram.Nodes.Add(shapeNode);
could you please give me some help ?
thanks.
Re: How to Rotate the Default shapenode?
Reply #1 - Apr 1st, 2015 at 7:29am
The shape rotates but you wouldn't notice when width and height are equal. I suppose you need the text to rotate too, set shapeNode.RotateText = true to enable that.
heyx
Reply #2 - Apr 13th, 2015 at 2:13am
hi Stoyan,
   Thanks for your help, It Works.
