Normal Topic Is there some method to select all the item on Diagram? (Read 1673 times)
heyx
Apr 13th, 2015 at 2:17am
hi,
I want to select all the item on Diagram, Is there some method to get it ? or use code ?
Re: Is there some method to select all the item on Diagram?
Reply #1 - Apr 13th, 2015 at 11:07am
Try this:
private void OnEditSelectAll(object sender, RoutedEventArgs e)
    foreach (var item in diagram.Items)
        diagram.Selection.AddItem(item);
