Normal Topic Node selection behaviour (Read 5756 times)
dittu
Apr 17th, 2015 at 7:02am
Hi Stoyo,
Can you please help me out on following duagramming issues:
1.) Is there an anyway to handle click event on canvas and not on node, as onnodeclicked event gets fired when node is selected, clicking on canvas, deselects that node. So, either I need is onnode deselect event or on click on canvas but not on other node?
2.) I have selected  "SelectOnly" Behaviour, how can I get hand cursor on mouseover of nodes?
3.) On selection, I want to change the colour of AdjustmentHandles which appear. Is there a way to do so?
Thanks a lot in advance.
Re: Node selection behaviour
Reply #1 - Apr 17th, 2015 at 7:41am
There are events raised both for diagram-click and deselect node actions:
var Events = MindFusion.Diagramming.Events;
diagram.addEventListener(Events.nodeDeselected, function (sender, args)
	console.log("node deselected");
diagram.addEventListener(Events.clicked, function (sender, args)
	console.log("diagram clicked");
You can find all supported events listed here:
http://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm?T_MindFusion_Diagramming...
Reply #2 - Apr 17th, 2015 at 7:53am
Try this:
var SelectOnlyBehavior = MindFusion.Diagramming.SelectOnlyBehavior;
SelectOnlyBehavior.prototype.setMouseCursor = function (point)
	var node = this.diagram.getNodeAt(point);
	return node ? "pointer" : "default";
Set the Diagram.handleBrush field:
diagram.handleBrush = '#4488CC';
dittu
Reply #3 - Apr 23rd, 2015 at 11:21am
Thanks Stoyo, everything worked.
But in case of Adjustment Handler on Chrome, sometimes (initially) I'm getting distorted circular handlers after some clicks here and there those get converted to square ones. Is this a know issue or any kind of workaround?
Reply #4 - Apr 23rd, 2015 at 4:28pm
There are round handles drawn for nodes with HandlesStyle.RoundAndSquare or for some control points of Bezier links, so you could see them change if you set node.HandlesStyle or link.Shape properties from click handlers. I can't see any distortions in Chrome though, could you attach a screenshot?
dittu
Reply #5 - Apr 24th, 2015 at 8:48am
Hi Stoyo,
PFA AdjustmentHandlers getting changed automatically.
Reply #6 - Apr 24th, 2015 at 6:07pm
I was able to reproduce this after setting node's StrokeDashStyle to non-solid style. Apparently the handles rendering code isn't resetting context's LineDash before drawing, and if handles happen to draw immediately after dashed border, they are rendered dashed too (even if your node's pen is set to "transparent"). So you could either set StrokeDashStyle to Solid, or fix the rendering code like this for time being:
var HandleUtils = MindFusion.Diagramming.HandleUtils;
var originalDrawHandles = HandleUtils.drawSquareHandles;
HandleUtils.drawSquareHandles = function (context, item)
	if (context.setLineDash)
		context.setLineDash([]);
	originalDrawHandles.apply(null, [context, item]);
