Normal Topic Logic gates demo (Read 1950 times)
billcollis
I love mindfusion
Logic gates demo
Apr 18th, 2015 at 1:06am
I was using the Logic Gates demo and I notice that when a diagram is saved and then reopened that the number of the node counter starts from 0, and not from the highest numbered nodes in the opened diagram.
If the diagram is modified after opening and then the result is generated it can crash.
Just need to change it so that the counter variable is updated using the highest value from nodes tags in the opened diagram
I added this to the code I have used from the demo
            string[] s;
            int i=-1;
            counter = -1;
            foreach(DiagramNode node in diagram.Nodes)
                s = node.Tag.ToString().Split('|');
                i = Convert.ToInt32(s[1]);
                if (i>counter)
                    counter=i;
Thanks again for great product
Bill
Re: Logic gates demo
Reply #1 - Apr 20th, 2015 at 7:12am
Thanks for notifying us about the problem, we'll fix this for next release.
